That's like saying, If you don't like doing english at school why bother studying it ;)
you do realize how dumb you sound? the fact you allowed yourself to type that AND click post reply.
wow.
amazing.
wow.
amazing.
wow.
amazing.
No, your obviously just a f**king idiot.
Reread what I said.
the analogy stands.
Just because someone is not a fan of something, doesn't mean they cant observe and learn about it.
I have an interest in cars, my knowledge would become pretty one dimensional if all I did was look at skylines (not to say Skylines are the only car that interest me) wouldn't it.
I like some Lambo's just not this one.
I know it's hard for pole smoking fanboys to understand, but some people just enjoy cars from the engineering standpoint even if they are f**king hideous (my opinion) which is all I ever said.
Peace.
meh, dont really care much for it. ill never own one, ill never see one, ill never drive one. i cant get enthusiastic about somthing that is such a myth.
  • 3 weeks later...
Although it may be a new car with new fandangled bits, the exterior is too Reventon styled for me. Not only does it take away from the epic limited edition design of the Reventon but at the same time, the exterior design isn't anything spectacularly new.
I'm sure Lamboghini are on the ball when it comes to designing supercars and the giant air vents sucking up small children through the nose has a purpose and serves it well, but I would have liked a newer aerodynamic looking model.
The back end is top notch. Love the LED tail lights but not sure bout the massive gap from the undertray. I'm sure it's got something to do with air flow and downforce, etc but I reckon the back should finish just a tad lower before seeing the carbon fibre bits.
The Countach and the Murcielago SV are still my 2 fav Lambos ever.
Interior is sh|t hot. Love the red on black combo. Dash setup looks like it came from the Toyota LFA though. A lot of nerdy compy PS3 kinda stuff. Secksy analog dials FTW.
I'm assuming that this car is a 7 or 8 speed DSG kinda setup but after watching Whiplash's video, it sounds like the clown driving it is riding the clutch harder than a new manual driver trying not to stall at the lights.
Having said that though and my not super impressed can't wait for it attitude, I'll take mine in either pearl white with black rims or just the basic matte black with black rims.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
