  • Replies 192
Yeah might pull my finger out and look at doing a all day sunday cruise up to the sunny coast, there is a nice road up to Maleny, plus a nice waterfall to go for a swim up there, picnic area and such, was thinking about looking at something to that likeing to get those poor SC members something to do :D but atm it's just all hearsay, I'll see how this cruise goes before organising something that big :)
Ah ye of little faith!
No really thanks for the help strutto, if it werent fer you I prolly would have chickened out, and you have provided so much help, thanks!
Also thanks for the passengers seat :) I cant wait, this is going to be aWeSoMe!!
Hmmm ..
hmmm...
hmm......................
i know ill be taking it VERY slow this thursday..
due to me being fresh outta hospital, and also because the skyline isnt insuresed and i have no money to replace it
Me too, mostly because i just spent close to $4k in cash fixing it back up...
So i will keep you company at the rear...
The route sounds good! Just not sure whether I am up for a run like that this week, feeling a little tight at the moment, hence the frequent sightings of me in the mini. Haven't driven the skyline at all for 2 weeks!
Brisbane Linesters
7.45pm @ Milton Maccas and departing @ 8pm sharp. I will be personally escorting Aaron this time round :)
1) me
2) Charly
3) Yoparata
4) Yamutha33
5) NA_R33
6) Predator with twoquik as co-driver
7) phatmirage
8) R33_Steve (pls confirm)
9) jlnewton - if not feeling tight & lazy :)
am i missing out on anyone else? Nismogirl? Haro? you in for this one?
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
