  • Replies 192
Yeah might pull my finger out and look at doing a all day sunday cruise up to the sunny coast, there is a nice road up to Maleny, plus a nice waterfall to go for a swim up there, picnic area and such, was thinking about looking at something to that likeing to get those poor SC members something to do :D but atm it's just all hearsay, I'll see how this cruise goes before organising something that big :)
Ah ye of little faith!
No really thanks for the help strutto, if it werent fer you I prolly would have chickened out, and you have provided so much help, thanks!
Also thanks for the passengers seat :) I cant wait, this is going to be aWeSoMe!!
  mindflux said:
Hmmm ..
hmmm...
hmm......................
i know ill be taking it VERY slow this thursday..
due to me being fresh outta hospital, and also because the skyline isnt insuresed and i have no money to replace it
Me too, mostly because i just spent close to $4k in cash fixing it back up...
So i will keep you company at the rear...
The route sounds good! Just not sure whether I am up for a run like that this week, feeling a little tight at the moment, hence the frequent sightings of me in the mini. Haven't driven the skyline at all for 2 weeks!
Brisbane Linesters
7.45pm @ Milton Maccas and departing @ 8pm sharp. I will be personally escorting Aaron this time round :)
1) me
2) Charly
3) Yoparata
4) Yamutha33
5) NA_R33
6) Predator with twoquik as co-driver
7) phatmirage
8) R33_Steve (pls confirm)
9) jlnewton - if not feeling tight & lazy :)
am i missing out on anyone else? Nismogirl? Haro? you in for this one?
    • How to wreak havoc at a bogans party... Swap out the goon bag hanging from the clothes line with oil bag... Watch chaos ensue during Goon of Fortune....
    • Hey everyone,   I’m looking for some advice on replacing the timing belt on my RB25DET Neo-powered 1998 Skyline. The engine was fully built about five years ago, including a fresh timing belt, water pump, and other essentials. However, since then, the car has only covered around 2,000–3,000 miles. It’s currently making around 650hp.   Even though the mileage is low, I know timing belts have a time-based lifespan too, and most recommendations suggest changing them every five to six years or 50,000 miles. Since I’m at that time mark, I’d rather not take any risks and plan to swap it out soon.   A few things I’d like to hear opinions on: 1. What’s the best belt for this setup? Should I go with an OEM Nissan belt, or is the HKS fine-tune a better choice given the power level? 2. Would you bother replacing the idler pulley and tensioner at the same time, or only if they show wear? 3. When swapping the belt, is it necessary to lock the cam and crank gears in place, or is lining up the timing marks enough? I’ve seen different approaches, and I want to make sure I do it right.   The water pump was changed with the rebuild and isn’t run off the timing belt, so I don’t see a need to replace it again. I just want to make sure I approach this the right way.   Any insight would be much appreciated. Thanks!
    • How does this compare to the internally gated g25-550 in terms of power production at same psi and spool
    • Did you find that your voltage of the battery wasn't where it's normally supposed to be? for example on my r34, it's at 14.5v when running after a few seconds, but I noticed when I had a rough start and it initially wasn't idling correctly, the voltage on my triple gauge cluster was showing lower than usual. Seems like the alternator is starting to crap itself
