  • Replies 192
Too bad your not coming James, I wouldnt be coming either except for Adrian is kindly giving me a navigators seat again, my beast hopefully will be back in my possession tomorrow, hope yours is back up to being as slow as ever soon :)
Brisbane Linesters
am i missing out on anyone else? Nismogirl? Haro? you in for this one?
I will NOT be a the Brissy starting point. I will leave brissy at 8:30 and see you all at Yatala BP...i will be passenger in either white or black GTR. See you all then....fingers crossed about possible rain.
Haro
HARO were you not at the last meet with the 2 gtr's and the bllue silvia. why didnt you come chat/mingle? would have been better to know some people.
Ummm that wasnt me..... this will be my maiden voyage with the skyline crew. But we will definately be meeting and greeting as we have a few things that some may interesting..... ill see you all this evening.
HAro
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
