R33Gtr Rear Diff And Drive Shafts Into An S14
Not the headlight. It's the DRL that serves double duty as white and amber. Would be the easiest way to make it happen, if fitting a BCM was in any way an easy thing. Otherwise you'd do it with some relay logic and/or maybe some diodes.
Would require a very smart body control module which these cars are about 20 years to old to have
Sounds like using one of those configs modern cars use where they turn off the whole headlight these days on the side that the indicator is flashing on.
Change the pump... Or you'll likely regreg it in 12 months time if it's clunky...
