I've purchased another wreck for the engine so eveything else is up for grabs.
Tell us what you need and I'll tell you if I have it, some pictures and prices are below...
Black R32 Gtr front guards
No dents but have some scratches, overall good condition
$200 each
Original R32 Gtr suspension front and rear in perfect condition $400 for the full set
Gtr stock intercooler in good condition $150
I also have the stock BOV's $120
BOV return pipe $120
All piping from engine to IC and IC to engine including metal through pipe through chassis(both sides) $250
OR buy the whole she-bang $600
Gtr front lip $150
Painted black with some scratches
Rear seat top and bottom $150
Stock computer for Nisstuning $150
Tail light in black $80 each, excellent condition. Also have white and grey
Kick panel $10
Complete centre console $40
Black Gtr grille $50, also have grey
Gtr side skirts and pods $200
Trust Gracer rear pods $160 very good condition in black
Pair of Gtr head lights with HID kit, ballast resistors etc $400
Front indicators $40 each
Full set of floor mats in good condition, light grey in colour $150
HKS top hard pipe kit $260, includes Apexi BOV (works well with the stock BOV and the plumb back)
Apexi pod filter (almost new) $200
R32 Gtr front bar in black some scratches, n1 vents and reo included $400
R32 Gtr fuel tank $50
Catback 3.5 inch exhaust $200
Other parts - pics not available
Brake master and booster $100
Clutch master $50
Clutch slave $50
Stock front pipe $50
4" titanium cat back exhaust $500
Pedal box $100
Complete aircon setup $150
Front drive shafts $100 each
Grey boot with N1 lip $350
ABS unit $120
Radiator with shroud $120
Brake lines $40
Body loom $100
Dash loom $100
Nardi steering wheel with boss kit $100
Stock Gtr steering wheel $50
Front Gtr hubs $100
Lower control arms $50
Castor rods
Gtr rear diff in good condition $350
R32 Gtr doors $150 each (white) non side intrusion
R34 Gtr rims in white with new rubber $2000
Located lower Blue Mountains, Sydney
Pick up preferred however can post at buyer's expense
Pete
0448468884
https://www.sau.com.au/forums/topic/356435-wrecking-r32-gtr-black-sydney/
  • Replies 128
Do you have the triple guage cluster surround (Just the black piece of plastic with the three holes cut out for the guage)?
If so could you post a pic and price?
yea say 15 bux delivered
will have to get a pick for ya
yea will get jenna to take a pick tomorrow when its not dark
hey mate where bouts in blue mountains, i am at glenbrook and i am after a few things very interested in headlights and a few interior pieces!
let me know
cheers
let me know
cheers
valley heights
give me a bell and come check it out
pete
0448468884
Gtr lip+sideskirts and rear pods, posted to Melbourne?
probabl be around the 80 mark( will have to be packed well to avoide breakage)
but if you can wait till the GP i am driving down so sling me 50 and ill drop it at your joint ( subsidise my fuel bill)
pete
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
    • Got started on the modification to make these splash plates fit over the long weekend. First the surprisingly time consuming task of swapping all the cam cap bolts to Tomei cam cap studs. I did the method of removing one bolt at a time, applying loctite to the stud, double nutting to torque as the manual described. Then carefully unlocking the nuts without disrupting the torque of the stud (and going back to re-torque a few times when it slipped). Finally applying the nut and torquing to spec. Repeat x28 Next up I went about removing the stock cam cover baffle so I could ensure it was fully clean after drilling for stud clearance.  As the blind rivets holding the baffle on were domed I used a punch to mark the center then used 4mm drill bit to carefully drill out the rivet without going too far part the baffle. As seen in other thread here is what is inside the stock baffles I decided on M4x6mm bolts to bolt the baffle plate back on with. I used a 3.3mm drill bit with some tape to mark the depth at ~8mm. Next was to tap the threads using a cheap bunnings kit M4x0.7. With the baffle removed I also drilled out the spot welds holding in the baffle plate oil returns. Unsure whether this was the best option or if I should have cut holes in the Hypertune splash plates to allow the oil drains to still function... time will tell. I then removed the the Hypertune splash plates so I could rest the cam cover on top and use a dab of grease to mark where the studs impacted the oem cam cover baffle. The most obvious spot was on the hump from the stock mesh is held. Using this hole as an anchor I bolted the oem baffle plate back into the cam cover and lined up the Hypertune splash plate. Marked the rest of the holes for the studs and drill those out too. Total 32 holes drilled and 12 threads tapped on the passenger side cam cover alone for this bolt on part that totally clears all OEM cam covers.. Drivers side next as well as some E85 safe fuel foam to fill the space behind the behind cam cover baffle plates. oh and some lock nuts for the splash plates of course.
