  • Replies 128
update
all parts came from this beast!
Black R32 Gtr front guards
No dents but have some scratches, overall good condition
$200 each
Original R32 Gtr suspension front and rear in perfect condition $400 for the full set
Gtr stock intercooler in good condition $150
I also have the stock BOV's $120
BOV return pipe $120
All piping from engine to IC and IC to engine including metal through pipe through chassis(both sides) $250
OR buy the whole she-bang $600
Gtr front lip $150
Painted black with some scratches
Rear seat top and bottom $150
Stock computer for Nisstuning $150
Tail light in black $80 each, excellent condition. Also have white and grey
Complete centre console $40
Black Gtr grille $50, also have grey
Gtr side skirts and pods $200
Trust Gracer rear pods $160 very good condition in black
Pair of Gtr head lights with HID kit, ballast resistors etc $400
Front indicators $40 each
Full set of floor mats in good condition, light grey in colour $150
HKS top hard pipe kit $260, includes Apexi BOV (works well with the stock BOV and the plumb back)
Apexi pod filter (almost new) $200
R32 Gtr front bar in black some scratches, n1 vents and reo included $400
R32 Gtr fuel tank $50
Catback 3.5 inch exhaust $200
Gtr rear diff in good condition $350
gtr front diff with welded on extension(you dont get the lsd centre just the casing) $200
stock front diff with diff centre $250
ohlins coil overs front and rear(r32 gtr) $400
rears good fronts questionable
tanabe suspension height and rebound adjustable need a clean but work well $400
4 inch cat back zorst sold to me as a ti exhuast i thing it is except for the muffler which is stano $500
belive it or not its under this crap
Nardi steering wheel with boss kit $100
Other parts - pics not available
Brake master and booster $100
Clutch master $50
Clutch slave $50
Stock front pipe $50
4" titanium cat back exhaust $500
Pedal box $100
Complete aircon setup $150
Front drive shafts $100 each
Grey boot with N1 lip $350
ABS unit $120
Radiator with shroud $120
Brake lines $40
Body loom $100
Dash loom $100
Stock Gtr steering wheel $50
Front Gtr hubs $100
Lower control arms $50
Castor rods
R32 Gtr doors $150 each (white) non side intrusion
Located lower Blue Mountains, Sydney
Pick up preferred however can post at buyer's expense
Pete
0448468884
sold shit
Kick panel $10 n1gtr
Black Gtr grille $50 n1gtr
Mate bought an exhaust locally cause I ended up cbfing with postage issues & can't see rest of it in pics as its covered by stuff.
Stock steering wheel, good condition? Stiching/marks etc.
Edited by Ten Four
fury muff
probably take me a hour or two to clean out the stuff on top of it, so we both won that one!
:cheers:
$200 eachRight guard sold left available
the right hand side is a tad warn in the pick
Clutch master $50
Clutch slave $50
Pedal box $100
ABS unit $120
Brake lines $40
Body loom $100
Dash loom $100
Front Gtr hubs $100
Castor rods
Pete
0448468884
sold shit
Gtr front lip $150 stevel
centre console stevel
gracer pods sold bwr gtr
floor mats + radiator deposit taken r32-25y
front bar with reo sold helscream r32 $400
another update
hecktic plumback turbo smat $120
hks oil cooler $400
gtr key barrell $100 with key
jap fuel rail twin in one out alloy with fitings and fuel reg $300
fuel setup
044 pump
earls fitting
$300
fuel setup 2
040 pump
$250 has relay
Clutch master $50
Clutch slave $50
Pedal box $100
ABS unit $120
Brake lines $40
Body loom $100
Dash loom $100
Front Gtr hubs $100
Castor rods
Pete
0448468884
sold shit
stock r32 gtr stering wheel
gtr rear bood grey with n1 lip
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
