  • Replies 128
update
all parts came from this beast!
Black R32 Gtr front guards
No dents but have some scratches, overall good condition
$200 each
Original R32 Gtr suspension front and rear in perfect condition $400 for the full set
Gtr stock intercooler in good condition $150
I also have the stock BOV's $120
BOV return pipe $120
All piping from engine to IC and IC to engine including metal through pipe through chassis(both sides) $250
OR buy the whole she-bang $600
Gtr front lip $150
Painted black with some scratches
Rear seat top and bottom $150
Stock computer for Nisstuning $150
Tail light in black $80 each, excellent condition. Also have white and grey
Complete centre console $40
Black Gtr grille $50, also have grey
Gtr side skirts and pods $200
Trust Gracer rear pods $160 very good condition in black
Pair of Gtr head lights with HID kit, ballast resistors etc $400
Front indicators $40 each
Full set of floor mats in good condition, light grey in colour $150
HKS top hard pipe kit $260, includes Apexi BOV (works well with the stock BOV and the plumb back)
Apexi pod filter (almost new) $200
R32 Gtr front bar in black some scratches, n1 vents and reo included $400
R32 Gtr fuel tank $50
Catback 3.5 inch exhaust $200
Gtr rear diff in good condition $350
gtr front diff with welded on extension(you dont get the lsd centre just the casing) $200
stock front diff with diff centre $250
ohlins coil overs front and rear(r32 gtr) $400
rears good fronts questionable
tanabe suspension height and rebound adjustable need a clean but work well $400
4 inch cat back zorst sold to me as a ti exhuast i thing it is except for the muffler which is stano $500
belive it or not its under this crap
Nardi steering wheel with boss kit $100
Other parts - pics not available
Brake master and booster $100
Clutch master $50
Clutch slave $50
Stock front pipe $50
4" titanium cat back exhaust $500
Pedal box $100
Complete aircon setup $150
Front drive shafts $100 each
Grey boot with N1 lip $350
ABS unit $120
Radiator with shroud $120
Brake lines $40
Body loom $100
Dash loom $100
Stock Gtr steering wheel $50
Front Gtr hubs $100
Lower control arms $50
Castor rods
R32 Gtr doors $150 each (white) non side intrusion
Located lower Blue Mountains, Sydney
Pick up preferred however can post at buyer's expense
Pete
0448468884
sold shit
Kick panel $10 n1gtr
Black Gtr grille $50 n1gtr
Mate bought an exhaust locally cause I ended up cbfing with postage issues & can't see rest of it in pics as its covered by stuff.
Stock steering wheel, good condition? Stiching/marks etc.
Edited by Ten Four
fury muff
probably take me a hour or two to clean out the stuff on top of it, so we both won that one!
:cheers:
$200 eachRight guard sold left available
the right hand side is a tad warn in the pick
Clutch master $50
Clutch slave $50
Pedal box $100
ABS unit $120
Brake lines $40
Body loom $100
Dash loom $100
Front Gtr hubs $100
Castor rods
Pete
0448468884
sold shit
Gtr front lip $150 stevel
centre console stevel
gracer pods sold bwr gtr
floor mats + radiator deposit taken r32-25y
front bar with reo sold helscream r32 $400
another update
hecktic plumback turbo smat $120
hks oil cooler $400
gtr key barrell $100 with key
jap fuel rail twin in one out alloy with fitings and fuel reg $300
fuel setup
044 pump
earls fitting
$300
fuel setup 2
040 pump
$250 has relay
Clutch master $50
Clutch slave $50
Pedal box $100
ABS unit $120
Brake lines $40
Body loom $100
Dash loom $100
Front Gtr hubs $100
Castor rods
Pete
0448468884
sold shit
stock r32 gtr stering wheel
gtr rear bood grey with n1 lip
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
