  • Replies 128
pete,
need:
battery hold down (with bolts)
GTR fuel tank (with straps)
windscreen wiper cowl cover (with screw insert covers- intact please)
headlight seal (rubber panel behind headlight) with clips.
GTR bonnet catch brace/support
and quite a bit of other stuff I can't think of at the moment :)
need:
Battery hold down $20
Fuel tank $50 but no straps
Bonnet catch etc $20
Don't have the other bits. Postage will be $40 due to size of the fuel tank
Pete
bonnet catch : catch + mounting bracket ?(IE the piece that ties it to the top radiator panel and the lower panel?)
the rest is fine. what happened to the straps?
gday mate if u dont sell the fuel tank im interested as i heard gtr tanks are plastic and i have a gtst that i think has a internal rust issue, heard its a possible swap/solution any one heard if this is true also?
Just checked and it doesn't have the mounting bracket. Straps went to the scrap yard.
No worries mate will let you know if Chris doesn't want it
update 28/3/11
gtr front lip $140
scratched and one minor crack
Black R32 Gtr front guards
No dents but have some scratches, overall good condition
left available $200
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8812.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8807.jpg
Tail light in black $80 each, excellent condition. Also have white and grey
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8795.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8876.jpg
hecktic plumback turbo smat $120
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8872.jpg
Front indicators $40 each
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8785.jpg
Apexi pod filter (almost new) $150
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG00050-20110307-1705.jpg
R32 Gtr fuel tank $50
Gtr rear diff in good condition $350
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8842.jpg
gtr front diff with welded on extension(you dont get the lsd centre just the casing) $200
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8840.jpg
stock front diff with diff centre $250
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8839.jpg
ohlins coil overs front and rear(r32 gtr) $400
rears good fronts questionable
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8838.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8837.jpg
tanabe suspension height and rebound adjustable need a clean but work well $400
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8836.jpg
Nardi steering wheel with boss kit $60
the right hand side is a tad warn in the pick
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8849-1.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8850-1.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8851-1.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8852.jpg
hks oil cooler $350
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8891.jpg
gtr key barrell $100 with key
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8884-1.jpg
jap fuel rail twin in one out alloy with fitings and fuel reg $300
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8883-1.jpg
fuel setup
044 pump
earls fitting
$300
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8881.jpg
fuel setup 2
040 pump
$250 has relay
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8880-1.jpg
gtr front brakes with rotors lines and calipers $300
Other parts - pics not available
Complete aircon setup $150
Front drive shafts $100 each
ABS unit $120
Front Gtr hubs $100
Lower control arms $50
R32 Gtr doors $100 each (white) non side intrusion
turns out me tanks stuffed to rusty to be worth cleaning so im stuck with out a car with out one haha so looks like i gotta get on one so that would be good thx mate.
go for it. I'll grab another.
pete,
still want the rest of it though.
pete,
thx mate
fatz was either of those fuel step us used with this tank? as in could i make a complete setup for my r32 gtst with what u got? as then i might to interested in such items also as me fuel pump will probably need replacing one day soon also as of the amount of rust in tank? im going to try and clean up my fuel rail and gott my injectors into be cleaned atm.
hey mate,
do ya have a l/h turret (door apature) mould
dash centre demister vents
r/h inner door trim weather strip
l/h reverse light
let me know cheers
mold? get me a pick so i know what you mean
demister vent i actually have one in perfect nick $20( these are impossible to get off)
no door trim
reverse light yea should have one 30 bux
pete
thx mate
plugs into your stock setup
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
