  • Replies 128
other things available, pick will come as i pull it off ( the car that is)
boot with wing $150
gtr seats (these are perfect) $700
doors $100 each good condition
entrie gtr rear end $800 ( this is the entire rear cradle and everything in it)
gtr motor (still to be tested and compression tested)2k-3k dpending on condition
gear box $600
abs $50
side skirts $100
everything behind the dash including wiring $300
rear wiring loom $200
centre consol $40
door cards $50
front window $100
rear window $100
rear quater windows $50 each
full seatbelt setup $100
brake master cylinder $40
clutch master and slave sylinder $100
steering collum $100 included key locks
rear seat $80
parcel shelf $40
attessa pumps $50
yea engine crossmember is fine $50
update for now
nismo 260km/h dash $280
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_9034.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_9045.jpg
3 guage cluster $40
aircon $40
nismo gear knob $60
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_9030-1.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_9070.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_9069.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_9068.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_9067.jpg
17X9 gtr offset rays lightweight rims (very light) $800
two with minor gutter rash
245/45/17 yoki DNA E-spec rubber 90% tread
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_9035-1.jpg
needs a wash but will do that when i pull them off
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_9041-1.jpg
rear bar $170 includes tail light
tail light 40 each
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_9057.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_9056.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_9055.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_9054.jpg
turbo back exhuast $500 includeds massive cat
velside exhuast?( thats what i was told)
cat back is stainless and in awesome nic (3,5 inches)
front pipe is tunned lenght hks ( seen better days)
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_9048-1.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_9049-1.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_9050-1.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_9053.jpg
brmbo front brakes $1100
includes calipers, new pads, two peice rotors lots of meat, brake lines and all bolts to install in your beast
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_9066.jpg
boot with wing $150
gear box $600
abs $50
side skirts $100
centre consol $40
door cards $50
front window $100
rear window $100
rear seat $80
parcel shelf $40
attessa pumps $50
Black R32 Gtr front guards
No dents but have some scratches, overall good condition
left available $200
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8812.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8807.jpg
Tail light in black $50 each, excellent condition. Also have white and grey
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8795.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8876.jpg
hecktic plumback turbo smat $120
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8872.jpg
Front indicators $40 each
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8785.jpg
Apexi pod filter (almost new) $150
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG00050-20110307-1705.jpg
gtr front diff with welded on extension(you dont get the lsd centre just the casing) $200
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8840.jpg
stock front diff with diff centre $250
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8839.jpg
ohlins coil overs front and rear(r32 gtr) $400
rears good fronts questionable
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8838.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8837.jpg
tanabe suspension height and rebound adjustable need a clean but work well $400
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8836.jpg
Nardi steering wheel with boss kit $60
the right hand side is a tad warn in the pick
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8849-1.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8850-1.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8851-1.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8852.jpg
hks oil cooler $350
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8891.jpg
gtr key barrell $100 with key
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8884-1.jpg
jap fuel rail twin in one out alloy with fitings and fuel reg $300
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8883-1.jpg
fuel setup
044 pump
earls fitting
$300
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8881.jpg
fuel setup 2
040 pump
$250 has relay
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8880-1.jpg
gtr front brakes with rotors lines and calipers $300
Other parts - pics not available
Complete aircon setup $150
Front drive shafts $100 each
ABS unit $120
Front Gtr hubs $100
Lower control arms $50
R32 Gtr doors $100 each (white) non side intrusion
  • 3 months later...
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
