  • Replies 128
update
all parts came from this beast!
Black R32 Gtr front guards
No dents but have some scratches, overall good condition
$200 each
Original R32 Gtr suspension front and rear in perfect condition $400 for the full set
Gtr stock intercooler in good condition $150
I also have the stock BOV's $120
BOV return pipe $120
All piping from engine to IC and IC to engine including metal through pipe through chassis(both sides) $250
OR buy the whole she-bang $600
Gtr front lip $150
Painted black with some scratches
Rear seat top and bottom $150
Stock computer for Nisstuning $150
Tail light in black $80 each, excellent condition. Also have white and grey
Complete centre console $40
Black Gtr grille $50, also have grey
Gtr side skirts and pods $200
Trust Gracer rear pods $160 very good condition in black
Pair of Gtr head lights with HID kit, ballast resistors etc $400
Front indicators $40 each
Full set of floor mats in good condition, light grey in colour $150
HKS top hard pipe kit $260, includes Apexi BOV (works well with the stock BOV and the plumb back)
Apexi pod filter (almost new) $200
R32 Gtr front bar in black some scratches, n1 vents and reo included $400
R32 Gtr fuel tank $50
Catback 3.5 inch exhaust $200
Gtr rear diff in good condition $350
gtr front diff with welded on extension(you dont get the lsd centre just the casing) $200
stock front diff with diff centre $250
ohlins coil overs front and rear(r32 gtr) $400
rears good fronts questionable
tanabe suspension height and rebound adjustable need a clean but work well $400
4 inch cat back zorst sold to me as a ti exhuast i thing it is except for the muffler which is stano $500
belive it or not its under this crap
Nardi steering wheel with boss kit $100
Other parts - pics not available
Brake master and booster $100
Clutch master $50
Clutch slave $50
Stock front pipe $50
4" titanium cat back exhaust $500
Pedal box $100
Complete aircon setup $150
Front drive shafts $100 each
Grey boot with N1 lip $350
ABS unit $120
Radiator with shroud $120
Brake lines $40
Body loom $100
Dash loom $100
Stock Gtr steering wheel $50
Front Gtr hubs $100
Lower control arms $50
Castor rods
R32 Gtr doors $150 each (white) non side intrusion
Located lower Blue Mountains, Sydney
Pick up preferred however can post at buyer's expense
Pete
0448468884
sold shit
Kick panel $10 n1gtr
Black Gtr grille $50 n1gtr
Mate bought an exhaust locally cause I ended up cbfing with postage issues & can't see rest of it in pics as its covered by stuff.
Stock steering wheel, good condition? Stiching/marks etc.
Edited by Ten Four
fury muff
probably take me a hour or two to clean out the stuff on top of it, so we both won that one!
:cheers:
$200 eachRight guard sold left available
the right hand side is a tad warn in the pick
Clutch master $50
Clutch slave $50
Pedal box $100
ABS unit $120
Brake lines $40
Body loom $100
Dash loom $100
Front Gtr hubs $100
Castor rods
Pete
0448468884
sold shit
Gtr front lip $150 stevel
centre console stevel
gracer pods sold bwr gtr
floor mats + radiator deposit taken r32-25y
front bar with reo sold helscream r32 $400
another update
hecktic plumback turbo smat $120
hks oil cooler $400
gtr key barrell $100 with key
jap fuel rail twin in one out alloy with fitings and fuel reg $300
fuel setup
044 pump
earls fitting
$300
fuel setup 2
040 pump
$250 has relay
Clutch master $50
Clutch slave $50
Pedal box $100
ABS unit $120
Brake lines $40
Body loom $100
Dash loom $100
Front Gtr hubs $100
Castor rods
Pete
0448468884
sold shit
stock r32 gtr stering wheel
gtr rear bood grey with n1 lip
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
