  • Replies 128
mold? get me a pick so i know what you mean
demister vent i actually have one in perfect nick $20( these are impossible to get off)
no door trim
reverse light yea should have one 30 bux
pete
here is that pic of the mould
31/3/11
Black R32 Gtr front guards
No dents but have some scratches, overall good condition
left available $200
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8812.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8807.jpg
Tail light in black $50 each, excellent condition. Also have white and grey
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8795.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8876.jpg
hecktic plumback turbo smat $120
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8872.jpg
Front indicators $40 each
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8785.jpg
Apexi pod filter (almost new) $150
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG00050-20110307-1705.jpg
gtr front diff with welded on extension(you dont get the lsd centre just the casing) $200
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8840.jpg
stock front diff with diff centre $250
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8839.jpg
ohlins coil overs front and rear(r32 gtr) $400
rears good fronts questionable
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8838.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8837.jpg
tanabe suspension height and rebound adjustable need a clean but work well $400
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8836.jpg
Nardi steering wheel with boss kit $60
the right hand side is a tad warn in the pick
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8849-1.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8850-1.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8851-1.jpg
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8852.jpg
hks oil cooler $350
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8891.jpg
gtr key barrell $100 with key
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8884-1.jpg
jap fuel rail twin in one out alloy with fitings and fuel reg $300
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8883-1.jpg
fuel setup
044 pump
earls fitting
$300
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8881.jpg
fuel setup 2
040 pump
$250 has relay
http://i236.photobucket.com/albums/ff9/fatzgtsr/IMG_8880-1.jpg
gtr front brakes with rotors lines and calipers $300
Other parts - pics not available
Complete aircon setup $150
Front drive shafts $100 each
ABS unit $120
Front Gtr hubs $100
Lower control arms $50
R32 Gtr doors $100 each (white) non side intrusion
i think i have one of the molds in the shed bit will take some time to find it
please msg me as soon as you know mate and i will take the other bits as well so msg me ya bank details plus cau ya work out postage to wingham nsw 2429. thanks jason
lucky for you i just snapped up another r32 to wreck
so i now have a full set off the things you want!
whooooooooo
whooooooooo
full car or half car?
if full - how complete is the car?
Fatz. I'm after a drivers side indicator. Got any left? Postage to qld 4068. PM details etc.
apparently someone has deposited the money for the pair i had
if it doesnt come through monday they are yours
pete
whooooooooo
sweet mate well can ya work out your prices and let me know and give me ya bank details and ill deposit the money asap cheers
directly relates to how had it will be to get off
but 20 bux plus postage sounds reasonable
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
