My friend has got this problem with his R34 Grey skyline that has a very low rear spoiler. He wants the spoiler a good few cms higher so it stands out more. Does anyone know if this is actually possible without having to buy a new spoiler?
If worse comes to worse how much would it take to buy and fit a new spoiler onto the skyline?
Here is a picture of how low the spoiler is:
Edited by Grey
https://www.sau.com.au/forums/topic/356451-low-spoiler-problem/
Picture looks like a factory sedan spoiler - you could just replace it with a coupe spoiler?
They usually go for $150-200, depending ... You'd then need to get it painted obviously - no idea on cost, you'd need to talk to a panel beater..
Yeah, that looks like a sedan spoiler, which sits lower than the coupe.
I can think of 2 reasons why people would change it.
1-personally taste
2-lower so it doesn't block drivers rear vision too much
The other thing that's worth noting is that the end-bits on the sedan spoiler are not as large as on the coupe spoiler, so even if you did raise it, it wouldn't quite 'look right'.
I've attached some comparison pictures of my R34 sedan where I replaced my sedan spoiler with a coupe spoiler, so you can see the differences:
Click for larger images.
Hopefully that will clarify the differences. As has already been mentioned - people like to be different, so it wouldn't surprise me if that is a sedan wing on a coupe. It's a fairly straight forward swap to go between them too, so it should be nice and easy to go back to putting a coupe wing back on.
The only way I can think of - off-hand - to raise it would be to use the nismo wing stays, which were designed for the coupe wing. Not sure if they'd fit the sedan wing. This would be a pretty expensive option, and would also require painting:
Nismo wing stays are heaps expensive. I was lucky to find a set for $100 posted lol.
I used the stays without the bottoms bits, looks pretty good.
But I think your best option would be finding a coupe spoiler, I saw one that's silver for sale few weeks ago for $100, in Melb.
Also, I'd be interested to see a side on pic of the sedan spoiler on coupe :D
Okay, so I have found a coupe spoiler that was originally made for a grey r34 GTT coupe, the owner took it off and is selling it to me, now I just want to know how easy it is to remove the low spoiler and refit it with the new GTT spoiler that I bought, will it take welding? Glue? Sticky tape? Holes that don't match? Screws that don't match? Rainy day leaks?
With regards the color - check the paint code under the bonnet - should list one of something like KV2, KR4, etc. If you're trying to buy the right color one, you want to make sure the color codes match.
To remove the spoiler, pop the boot, undo all of the clips on the underside holding the boot-lining in-place. You just need to twist to undo, then pull them off. Once the boot-lining is off, you'll be able to see up to the nuts holding the spoiler on. There should be two bolts on each side - I think they're 10 or 12mm. You'll probably need a fairly small smaller and extension to get in there.
Once these are off, it depends how the last owner fitted the spoiler; likely you'll need to use something like fishing line to cut the double-sided tape or whatever material they've used to hold the spoiler on and protect the paintwork.
With regards to the holes, the rear bolt hole is the same but the front bolt is in a slightly different position between the coupe and sedan. However, since you a coupe it's possible that it had a coupe spoiler on at all (than no spoiler at all) and if you're lucky there may still be the original holes there.
From there, it should be a simple matter of putting the new spoiler with something like automotive double-sided tape to protect the paintwork, and then bolting it on from behind - the nuts from the spoilers are the same size. Then you can just put the boot-lining back on and voila - you're done.
When I swapped my sedan spoiler for a coupe spoiler on my sedan I haven't had any leaks or dramas, so if you do it right you should be fine. If you're worried, talk to a panel beater maybe?
Good luck with it.
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
    • I recently purchased a 2018 Infiniti Q60, which has an SD card navigation map. I can see my system has options for real time traffic updates etc, and am wondering if there is something I can purchase to get this working? I can see there are at least updated maps for USA and Canada, but nothing for Australia. Surely Infiniti took changing road systems and city expansions into account when they decided to use an inbuilt navigation over Android Auto/Apple Car Play, or are we doomed to drive on streets that don't exist in the navigation system if you drive to a new area?
    • Luckily I didn't put in etch primer as I just found out it's not compatible with my body filler lol. Also just need to sand the panel anywhere between 150-400 grit so I'm in the clear there. It does say to not apply to soft old paint, I assume that means paint that is flaking, peeling,etc
    • @dbm7 and @GTSBoy thank you both very much! will give that a shot!
