pretty sure there was a thread about this maybe 6 or so months ago. think if i remember correctly most people agreed it was to do with incorrect torquing. cant remember other ideas suggested...
+1
Very sensitive to the way they are removed and installed. Slow and steady by undoing all the bolts a little at a time is the safe way, same when doing them up. It's due to the length of the cams and which lobes are compressing their respective valve springs part way along the cam.
If you put on and do up the caps unevenly or one at a time, fracturing/weakening and or breakage may occur.
Or if the cam has never been out than check thencam belt
Hasnt slipped causing the exhaust valves to contact pistons then snapping the cam.
Couldnt u hear the engine had no compression when cranking?
Cranked like a normal engine as the valves are all shut so it would have had compression even if we tested it. Belt is fine, tight as f**k and absolutely no way it has slipped.
Doesn't look like an oil supply issue either as there was plenty of oil and the two bearings I checked (next to the snap) look brand new.
Edited by Rolls
Yer my mate snapped one. As said above it was due to incorrect instsllation procedure. He tried to start tightening from the center but because the valves were holding the two ends of the shaft up it must have started to bend and then it snapped when he applied pressure on the next bolts.
Silly mistake really but it was his first major engine work. Was years ago now.
If you have not had the camshafts out could maybe suggest that timing belt was over tention or it slipped a tooth. Surely u would of heard valve to piston noise if any contact occured tho.
Cant over tensioning the timing belt load up the front of the shaft. the extra tension is trying to pull the front of the camshaft downwards. And even the smallest amount of deviation to the cam rotation will cause u a problem
Could a seized lifter also cause the cam to snap? Been speaking to a few people and a mate whos rebuilt 30+ motors reckons he has seen it all the time where if someone rebuilds a head and puts the lifters back in out of order etc it can happen.
I have a spare cam so might take all the lifters out, see what the deal is, then compression test it with the other cam, who knows might be lucky and all the valves are sealing, only take 10 minutes to try vs taking the head off, nothing to lose by trying it.
Be easier to take the whole engine out than to take the head off.
Yer posibly it could seize. Is ur engine an rb20? They is hydrolic lifter so would be rare for anything to cease up I would of thought but ur mate might well be right. But yer if you strip a head down its important to make sure any parts that are being re used go back where they came from.
I have my timing belt and all associated gear off at the moment due to doing some maintenance. God I hate doing it so much. I've done it about 10 times since owning the car and it never gets easier, always end up having no feeling in my fingers for a week.
We will stick a boroscope in there as well, but it takes 15 minutes to change the cam and it takes what 5+ hours to remove the head then gotta do gaskets and all the old hoses that will no doubt snap. I have nothing to lose by putting another cam in and compression testing, takes no time at all, I don't want to pull the head off and find it is all ok in there, and if I pull the head off and its stuffed I need to get another motor anyway.
lysdexia over on the 31 forums said he snapped a cam in a 25 and got off with no bent valves or pistons some how, turned it over hundreds of times as well, cause if the cam snaps wont all the springs try and close all the valves and just put the cam in the position with them all as closed as possible?
it wont though because there is always at least one cylinder with open valves, so my money would be on some valve / piston contact in the cylinders that are at the rear of the motor (the side that had no drive to turn the camshaft)
Edited by Bl4cK32
    • Getting a decent signal from all 6 throats is a challenge. I don't know for sure, but I suspect that the stock balance tube is not ideal for it. I have done it on an ALFA 4 cylinder (about 35 years ago, so don't ask for too many details). We drilled 4x holes in the manifold runners, put in some fittings and ran hoses to a decent sized (I think it was about 20mm diameter) pipe that ran the length of the inlet manifold. So, it was quite a decent volume. There is a "tuning" balance to be found between the volume of the common plenum on such a thing and the diameter of the pipes running from it to the runners. You need the volume to be large enough to damp out the sharp spikes in pressure signal you get as each runner gets sucked on by its cylinder, but not so large that it becomes too slow to respond to actual changes in MAP. And you need the hoses to be small enough to transmit the signal quickly, but not so small that they delay the signal. You might have to have more than one go at it, if there isn't any actual success based wisdom to be had here. Hopefully there is. Anyway, I would not do it on only a couple of cylinders. I would also not care about "permanently modifying a part". Just bloody drill holes and make stuff better. There is nothing sacred about any GTR unless it is a genuine museum piece that you shouldn't be modifying at all anyway.
    • He's still joining you, he's just delayed it and won't have the fulleh sick ITBs...
    • The strange thing is this is a URAS front bumper (or clone of it). The bumper actually does not sit flush with the GTT hood - You need the addon to make the hood 'long' enough to reach the bumper. I have no idea why they didn't incorporate this piece into the bumper itself.. instead of sticking it to the hood instead.
    • Another thought on this OLD topic: When you paint your bonnet lip, leave a small unpainted back lip/line along the back of the lip, where it rests on the bumper. That way, the line in the back is much more prominent than the gaps in the front/under the lip - and it breaks the hood-to-bumper connection at the "correct" place, when comparing to a GTR. I'm gonna do this with mine this week, so stay tuned for pics!
    • So I'm in the final stages of assembling my single turbo RB30/26 and had a question regarding MAP reference points.  I've seen several recommendations such as tapping the cylinder 2/3 ITB, tapping the intake manifold at cylinder 2/3, or using a point on IAC. First two are doable but require permanently modify part and the third is "out" as I plan to delete the IAC.  All that to say my question is can I used the "bleeder" in the center of the ballance tube as a MAP Reference? I'm running a catch can so I don't need it for the PCV system. My thought process is it "pulls" from all 6 cylinder, and it's between the ITB and the cylinders making it ideal for MAP reference according to what I can find. Thoughts?
