How Can An Exhaust Cam Snap?
By myrbgivesmeheadaches · Posted
Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was? I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts -
What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
