pretty sure there was a thread about this maybe 6 or so months ago. think if i remember correctly most people agreed it was to do with incorrect torquing. cant remember other ideas suggested...
+1
Very sensitive to the way they are removed and installed. Slow and steady by undoing all the bolts a little at a time is the safe way, same when doing them up. It's due to the length of the cams and which lobes are compressing their respective valve springs part way along the cam.
If you put on and do up the caps unevenly or one at a time, fracturing/weakening and or breakage may occur.
Or if the cam has never been out than check thencam belt
Hasnt slipped causing the exhaust valves to contact pistons then snapping the cam.
Couldnt u hear the engine had no compression when cranking?
Cranked like a normal engine as the valves are all shut so it would have had compression even if we tested it. Belt is fine, tight as f**k and absolutely no way it has slipped.
Doesn't look like an oil supply issue either as there was plenty of oil and the two bearings I checked (next to the snap) look brand new.
Edited by Rolls
Yer my mate snapped one. As said above it was due to incorrect instsllation procedure. He tried to start tightening from the center but because the valves were holding the two ends of the shaft up it must have started to bend and then it snapped when he applied pressure on the next bolts.
Silly mistake really but it was his first major engine work. Was years ago now.
If you have not had the camshafts out could maybe suggest that timing belt was over tention or it slipped a tooth. Surely u would of heard valve to piston noise if any contact occured tho.
Cant over tensioning the timing belt load up the front of the shaft. the extra tension is trying to pull the front of the camshaft downwards. And even the smallest amount of deviation to the cam rotation will cause u a problem
Could a seized lifter also cause the cam to snap? Been speaking to a few people and a mate whos rebuilt 30+ motors reckons he has seen it all the time where if someone rebuilds a head and puts the lifters back in out of order etc it can happen.
I have a spare cam so might take all the lifters out, see what the deal is, then compression test it with the other cam, who knows might be lucky and all the valves are sealing, only take 10 minutes to try vs taking the head off, nothing to lose by trying it.
Be easier to take the whole engine out than to take the head off.
Yer posibly it could seize. Is ur engine an rb20? They is hydrolic lifter so would be rare for anything to cease up I would of thought but ur mate might well be right. But yer if you strip a head down its important to make sure any parts that are being re used go back where they came from.
I have my timing belt and all associated gear off at the moment due to doing some maintenance. God I hate doing it so much. I've done it about 10 times since owning the car and it never gets easier, always end up having no feeling in my fingers for a week.
We will stick a boroscope in there as well, but it takes 15 minutes to change the cam and it takes what 5+ hours to remove the head then gotta do gaskets and all the old hoses that will no doubt snap. I have nothing to lose by putting another cam in and compression testing, takes no time at all, I don't want to pull the head off and find it is all ok in there, and if I pull the head off and its stuffed I need to get another motor anyway.
lysdexia over on the 31 forums said he snapped a cam in a 25 and got off with no bent valves or pistons some how, turned it over hundreds of times as well, cause if the cam snaps wont all the springs try and close all the valves and just put the cam in the position with them all as closed as possible?
it wont though because there is always at least one cylinder with open valves, so my money would be on some valve / piston contact in the cylinders that are at the rear of the motor (the side that had no drive to turn the camshaft)
Edited by Bl4cK32
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
    • The ones in brackets are the first stages of tightening. I usually aim for the middle of the range. They give a range because it's actually not that critical to hit exactly the right bolt tension. Enough is enough, and too much is too much, and the range given is inside that range. Half of the bolts in the suspension are problematic for putting a torque wrench on anyway, so just get done up to mechanic tight  and spanner checked a week later.
