Description:
Price$7,500.00 ono NEGOTIBALE
OR TRADE/SWAP
Address Sydney, New South Wales, Australia
NISSAN SKYLINE R33 GTST TURBO SERIES 2 MANUAL
* 180,000KMS
* APEXI ELECTRONIC BOOST/AIR FUEL CONTROLLER
* APEXI ECU
* GREDDY TURBO TIMER
* LARGE AFTERMARKET FRONTMOUNT INTERCOOLER
* AFTERMARKET CROME INDUCTION/INTERCOOLER PIPING
* POD FILTER WITH AIRBOX COVER
* CUSCO FRONT + REAR STRUT BRACES
* CUSCO FRONT + REAR SWAY BARS
* 3.5 INCH EXAUST FROM TURBO
* 5 INCH MUFFLER CANNON
* BRASS BUTTON CLUTCH
* R33 GTR BRAKES
* DRIFT GEAR KNOB
* WHITE LEATHER GEAR BOOT AND HANBARKE BOOT
* NEW AFTERMARKET YELLOW JAKET COILS
* NEW CAM SEALS AND BELTS
* VOLTAGE STABILIZER
* REV METER/ GAUGE
* DVD PLAYER WITH REMOTE
* NEW SPEAKERS X 4
* JBL 12INCH SUB IN BOX
* PRO COMPITION AMPLIFIER
(STEREO PUMPS)
* 4 NEW TYRES ON 17X8 RIMS
* BATTERY IS RELOCATED TO THE BOOT
* AFTERMARKET BODYKIT + SPOILER
* REGO TILL DECEMBER 2011
EXTRAS
* FULL STOCK EXAUST
* EXTRA REAR SPOILER
* 2 SETS OF SIDE SKIRTS
* SIDE MOUNT INTERCOOLER + PIPES
* ANOTHER TURBO TIMER
* BRAND NEW BLOWER VALVE
* SET OF 6 STANDARD COILS
* SOME INTERCOOLER PIPES
DRIVES WELL AND FAST PAINT JOB IN GOOD CONDITION SAD TO SEE IT GO BUT I REALLY WANT A FOUR DOOR I AM WILLING TO TRADE FOR AND 4 DOOR TURBOS LET ME KNOW WHAT YOU HAVE I AM NEGOTIABLE!!!
YOU CAN CONTACT ME ON 0424789916
THANKS FOR LOOKING!!!
I WILL RESPOND TO POSTS BUT YOU CAN ALWAYS CONTACT ME ON MY MOBLIE JAMES
PLEASE SEND ME YOUR OFFERS!!!
Edited by DRIFTDEVIL86
BAD POINTS:
* Radiator is patched at the top near radiator cap, car is still drivable just need to take it easy untill you replace. (Radiator is $80 on SAU forums)
* Someone tried to break into the boot and boot latch is now broken and boot is very hard to open (Boot cable is $20 on SAU forums)
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
