Im building an rb25 with rb26 crank, Eagle rods and some pistons that says 8.5:1 compression in rb26.
But does someone know how much the cr would be with rb25det head? What I understand is the chambers a little bit smaller in the rb25det head then in the rb26 head? I want about 9.0:1 CR So what type of gasket should I use to reach it?
https://www.sau.com.au/forums/topic/356478-what-cr-special-rb2526-hybrid/
What cr are u after? It all depends on wht fuel u are using and what the engine is being built for? Street circuit drag etx
I want 9.0:1 and will drive on e85. Will use the car as an allround some street,some drag and som track/drift. Nothing serious just for fun.
Yes from memory rb25 has smaller chambers in head. I think thats why they are 9:1 factorry and 26 are 8.5:1.
Most engine builder have a program that does a calculation to work out comp ratio.
they input...
head chamber size after any resurfacing has happened.
piston top size (in cc. Flat top is usually at 0cc. My dome tops were 13 cc I think.)
Head gasket thickness
and posibly gudgen pin height, rod length and stroke length.
They then select the block its for and the program does the calculation.
You can also use bore size inthere to get an overall displacement to I think.
Ask ur builder the question. As far as I know they regularly need to do these calcs
Everything I've seen suggests that standard RB25 and RB26 heads have the same config and volume in their chambers .
Usually manufacturers take the easiest read cheapest changes to get what they want in production engines . By this I mean pistons are I'd reckon cheaper to change from suppliers than cylinder head castings so it makes sense to me anyway .
My own opinion ? If possible change the static CR with pistons . I think different thickness headgaskets is a half assed way of changing things when its not intended to pull the engine out and do it properly . Thats fair enough for those on a budget but if is out and apart I reckon do it the way a good engine builder would and that means the appropriate pistons and an OE thickness headgasket .
The fact that its an RB25 head and generally a single throttle inlet system means IMO that 8.5 is too low . If it was running a 26 head/inlet manifold/cams then 8.5 is probably Ok .
The big difference with multiple throttles is you have far less resistance to inlet flow and the dynamic or effective compression ratio tends to be closer to the measure compression ratio . Nissan raised the static CR on RB25's because they knew the dynamic CR would be lower off boost and they wanted a bit more part throttle torque and no doubt improved throttle response and fuel consumption . The variable inlet cam would have had a say in this too .
Your call but I think 8.5 is too low in an RB25 and especially when using E85 , I would be thinking more along the lines of 9.5 and if you never use ULP again maybe a tad higher . I think what would happen with a low compression 25 headed engine is a low static compression ratio dragged to an even lower effective compression ratio by its inlet manifold system .
A .
    • I personally would run 2x from the cam covers into the catch can, 1x sump vent to catch can (would mount this at a low point of the catch can, so it can also act as a drain). I would see if you can run a -12AN down there to improve venting and also draining. The head drain thing, just drain that back to the sump on the other side. Catch can to be vented, unless you plumb or back to the intake.
    • Yeah the head "drain" is rather a sump/crank case vent. My catch can stopped filling up after venting the sump to the catch can. I have 4x fittings in mine, which is about 5Ls. 2x cam, 1x sump vent/catch can drain, 1x fitting back to the intake and a massive breather which can be blocked so it's a fully sealed system.
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
