Hey guys,
Ive searched around on this forum but could only really find answers for upgrades on stock gtst.
I just found out the Arc intercooler i ordered is no longer available due to them going bankrupt so now i want to pick out the best intercooler for my aplication.
The motor is a built 2.6l running a Hks T51Kai ( Looking at building a 26/30 in the near future). What does everyone recommend?
Cheers for your advice,
Edited by DTSNR32
https://www.sau.com.au/forums/topic/356479-best-intercooler-built-32/
Something 100mm (4") thick at minimum and a good jap brand.
I dont think anyone will be able to say what the best cooler is realistically... As long as it fits the bill.
PWR as stated above are good yet a local brand.. I would rather a Jap branded item (such as ARC) for known and reliable quality.
the thing with a high mount u need custom pipework. u dont need the pipework that costs an extra $500 that will come with an hks cooler kit. a plazmaman/pwr is more what u need. pwr is 81mm btw, and flows sht loads ;)
Best for your application ? What is that ?
Also, what is your typical ambient air temps ?
Do you still have aircon in the car?
How much power?
These relate to airflow to your radiator and what kind of core is optimal for your application.
A I/C that flows well is one thing, but doesn't mean it cools well.
It's a fine balance between flow & cooling.
I think a 0.5-1psi drop seems to be the norm for the reasonable cooling items.
1-1.5psi seems to be better cooling but obviously less flow. Comes down to what you want.
And something without a drop can't be mashing the air up too much you'd think.
Cheers for the your help so far guys.
How much power?
The car will be driven on weekends and down the quater mile. It no longer runs aircon and im yet to run the car with this setup so im abit unsure to what power it's going to make but hopefully 600+hp in the future. I was looking at the nismo intercooler but was unsure if there would be something better out there for around that price.There is a 140mm Arc cooler in the forsale threads but havent had a reply yet also will this be abit on the big side?
Edited by DTSNR32
And ambient air temps?
Are you sure there will be no in traffic driving. If the car is drag only, its hard to go past NXTIME's Trust intercooler for $1700. The nismo cores are another $700 on this.
http://www.skylinesaustralia.com/forums/topic/325811-trustgreddy-drag-intercooler-150mm-new/page__p__5628306__hl__drag+intercooler__fromsearch__1#entry5628306
Nismo is definatly more streetable as it wont interfere with radiator airflow as much as a drag(super thick) core will. Nismo parts are unbeatable for fitment and quality too. They come with all the gaskets, special bolts and new air temp sensor etc, all in Nissam factory part boxes. Without aircon you may get away with a drag core on the street though as well, you just have to be prepared to chop the hell out of your front bar to make it fit.
http://www.skylinesa..._1#entry5628306
Ambient air temps of South Perth id say mid/high 20s in summer and in winter around 14-15 degrees. I have been stopped before in traffic but only coming and going to workshops. It also runs a 55mm PWR x-flow radiator with thermo fan. The Nismo core is around 2200 from Nengun/Perfect run.
Cheers
Cheers
by south perth do you esperence?? mid/high 20's in summer ?? we've just had the first couple of days below mid/high 30's, if not 40's in months ,, I went to the drags a few weeks ago and at 7pm it was 32 degrees with a track temp of 45..?
Im talking about the average ambient temp not the max temps seen. If you look at the average over a day and night its lower than you think, plus i drive it mostly during the night.
Sounds like a nice place to live. Im getting sick of being washed away or melted/burnt to a crisp in our 35 degree+ 90+% humidity. Cooling struggles on a days like that, but I think you'll probably get away with the drag core in your moderate temps and with no aircon condensor restricting radiator airflow.
Another thought... the T51Kai is a bit big for 600hp. A T04z would make that power with less lag. The monster intercooler is going to add some lag too. Though if its drag only then anti-lag solves these problems.
  On 08/03/2011 at 8:30 PM, R31Nismoid said:
Both are too big for 600hp - a GT35 will make that and more.
On E85 you mean?
*Enter Fineline*
600HP/450KW implies 400rwkw, we are not yanks and we do not get those numbers with ease on these turbos. I like to think 350rwkw is more realistic, if you are lucky.
T04Z territory for sure IMHO.
  • Like 1
    • I much prefer that to an actual oil pressure issue, never would of thought it would of been a volt drop issue but SAU brains win again. Guess ill be turning down the oil pressure limit for the track and hunting some grounds. Ill hopefully update this thread with some high oil pressure and solid ecu voltage logs.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
