hey ppl up for sale my nissan silvia s13 king series
sr20det
113,xxx ks
manual with new brass button clutch and good 2nd hand 97 180sx gearbox
mods include
hypergear tr43i 0.63 turbo
tune agent top mount manifold with a ebay 38mm external gate and screamer pipe (sounds sik) everything is heat wrapped
all braided turbo lines,
custom made dump pipe 3inch all the way, 2 res and one muffler nice and quiet but dosent restrict flow
custom made intercooler using a xr6t cooler, no holes cut for the front mount looks good
asi 53mm twin core radiator with twin 14inch thermo fans
sard 550cc injectors
z32
gizzmo ebc
bosch 040 fuel pump
running a niztune the car is at the tuners currently, i should be gettin it back soon hoping to make a safe 220-230 rwkw on 17psi
i havent done more then 2500ks since ive done all these mods
body
body is ok just paint is faded on the front and front bar is a differnt red
near the sunroof there is alittle bit of rust
couple shopping trolling dings nothing major
interia
interia is good besides the crack in the dash, its a king series has the heads up speedo display and digital speedo, front seats are good, rear seats have couple ciggy burns from previouse owner
got a pioneer head unit to go with it aswell just been lazy to put it in
the cluster gives me trouble sometimes common problem theres a guy in adeilade thats fixes em besides that everything else works ciggy light power mirros
reason for selling
i love this car spent so much time and money on it, it starts everyday, im a mechanic and ive looked after her well, servied every 5,000ks or 3 months,
ive bought myself a r32 its gonna b sad to see her go but ive been buildin a rb25 and would b alot easyer to put it in my r32
history of the car
the guy i bought this off was in his late 20s early 30s, he started working in ACT for the goverment or sumfin like that and was rearly in melb and never drove it, he bought this when he was 18 from a car dealer and had it since, im the 2nd owner of this car since its been in australia, ive owned the car for 3-4 years bought it stock as a rock just with a exhaust and a gay front bar
her is the pictures
its got reg till september no roady ive have all the stock stuff like t25g stock manifold, stock cooler n pipin
im asking 8900
call or sms me on 0432 506 443
located south east surburbs
all it needs is a set of pistons and cams should make close to 300rwkw or more depends on ur tuner
that turbo is capiable of making 300+ kw on a sr20det
https://www.sau.com.au/forums/topic/356544-silvia-s13-sr20det-manual/
  • 1 month later...
ey ppl got my car bak made 197 on 14psi, with dyin coilpacks and shit fuel gona get new packs and some fresh juice there is alot more power to b made, ive put a stero in and fixed up little things
also price drop 8k got rego comin up soon in july so if i pay rego then 8300 for the car
  • 3 weeks later...
bump
will take any offers
car is runnin really good no dramas nothing cops dont even look at my car, gona get the front of the car cut and polished, fixed the sun roof and the rust on the roof hasent gone though the roof so only surface rust nothing to worry about
car can make alot more power only reason i made under 200 is coilpacks and shit fuel
sr20det
113,xxx ks
mods include
z32
gizzmo ebc
bosch 040 fuel pump
running a niztune 197rwkw on 14psi wot shit fuel had to keep retardin the timing
body
near the sunroof there is alittle bit of rust only sirface rust
interia
got a pioneer head unit plays ipod usb
reason for selling
history of the car
her is the pictures
its got reg till june next year no roady ive have all the stock stuff like t25g stock manifold, stock cooler n pipin
im asking 7500
sr20det
113,xxx ks
mods include
z32
gizzmo ebc
bosch 040 fuel pump
car is currently making 200rwkw on 14psi, tuner had to knock off alot of timing due to petrol beein old and coil packs breaking down under more boost
body
near the sunroof there is alittle bit of rust only surface rust tho nothing major
interia
digital cluster plays up
reason for selling
history of the car
her is the pictures
its got reg till nxt year jun, no roady ive have all the stock stuff like t25g stock manifold, stock cooler n pipin
im asking 7g
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
