WTF calm down!
He said that an RB26 is 400cc smaller than a 2J
Also fow do you have no problems flowing over 1000hp when you havent made 1000hp yet?
A car that makes 510 kw at the wheels thats almost 700hp. Can you convert that to FLYWHEEL ENGINE POWER. Its very close to a 1000 because its going through a automatic tranmission you will need to add about 20% on that drivetrain loss so as you can seethe head is more than capable of FLOWING over a 1000hp. Dont confuse that with rear wheel horspower.
Also as far as me being DAFT i know the RB30 is a single cam head. I just used it as an example as to why people use hybrids.
And saying a head has CC ratings is stupid.
Edited by Adelaideprosound
For those who claim a j engine sounds better than an RB, clean ya farken ears out. The j can scream but it cant snarl like an angry rb.
They are both amazing engines and can punch well above their weight. 1000 plus hp is achievable in either camp.
Yes the toyota can be made to handle, there are some fine examples of quick track cars around but you have to throw a shitload more coin at them to achieve it.
Drive what you like, they both outdo the local product by a wide margin but someone should have drowned the tool that designed the supra body.
You said sequential gearbox for starters...but ill leave it there.
yeah yup...a head sure does have cc ratings....
Noel - you are old and your ears cant handle the 1jz scream :P
also the body is fine...the dash is gross...but Id live with it
You may be right Zeb, Even screamer pipes sound like a busted arse to me. The anger of a hot rb on the other hand gives me wood. (or as close as you can get to it at my age)
You obviously dont know my car. If u think im lying head over to The Supraforums and check out the build page.
It has a fully built TOYOTA AUTOMATIC TRANSMISSION built by MV automatics, with a spragless stage 3 kit new gears, b&m quick shifter and full manual valve body so it shifts sequentially.
But its still an auto box.
The combustion chamber is measured in CC's....thats part of the head and can play a big role in how an engine performs.
Also port volumes are measured in CC's
Manual Valve bodies in an Auto does not make it a sequential box...its an Auto with a manual valve body :)
Anyway this isnt a thread about A340's so STFU now kthx
The combustion chamber is measured in cc's is it :), Dude u have lost the plot. Anyway, you made it about A340's not me, so as far me shutting up make me. I dare u to try it.
And its not just a manual valve body its a whole gearset.
My god.
No wonder I rarely venture to this part of the forum.
I live an breathe engines...so you go ahead and keep being incorrect and pulling your dick over your "sequential auto box" and I'll go on my merry way.
autos are ghey
... combustion chamber volume IS measured in cc's
+1
Thread delivers teh lulz. For the record most incarnations of 1.5jz come about when a 1jz powered vehicle has a 2jz bottom end bolted on to stroke it out 500cc. You'll seldom see it done the other way around, starting with a 2jz powered vehicle - only reason I can think of is that 1jz heads are probably cheaper...
As for the 26 head on a 30.....well that makes you sound rather daft.
RB26 head has 2 cams, 4 valves/cylinder solid lifters etc compared to the RB30 head which is SOHC 2 valve and hydraulic lifters
Well you'd put the 26 head on a 30 bottom end rather than a 26 head on an 30 head. A head on a head wouldn't make much power mate. :)
  • Like 1
Alright Captain Ahab,
Before you go on, go do some reading, because obviously you don't know what your f**king talking about.
Come back, apologize to zebra, and then apologize to the world for 'trying' to race a yacht.
Back On topic.
Personally not a fan of the sound of the J engine, have heard a few nice ones though, its all swings and roundabouts.
There are one or two very nice handling Supras, but , well that's my point there are one or two LOL.
And Birds if your going to the expense and trouble of building a hybrid, you wouldn't leave a worse performing head on it.
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
