got this spare with a car i bought, someone told me its a vlt rear housing (.63) and has the same stud pattern, but i dont know what the specs are, aside from the fact that it has been high flowed.
also, does anyone know if the highflowed components (wheels, housing etc) would be interchangeable with an r33 s2 rear housing? as ive already had a custom dump pip made to suit it.SAM_0041.jpgSAM_0039.jpg
https://www.sau.com.au/forums/topic/356595-what-kind-of-turbo-is-this/
do not use this turbo on a skyline. they are shithouse old design. i had one and it was rat shit.
You might be able to get the standard housing machined out to suit depends how big the rear wheel in that turbo is.
Sell it and get a better turbo, its just not worth using the old VL design the stock turbo will be better.
That "thing" , and I'm being nice , is the dreaded bastard hi flow bitzer turbo . The housings look a bit like RB20 on the compressor side and T3 on the hot side . The hub of the turbine looks a bit like a Hitach HT18S one .
Probably bore everyone but .
1)Comp housing inlet bored out a lot so a big wheel for a smallish compressor housing .
2)Hitachi turbine big which is fine for a Ser 4/5 RX7 Rotary but iffy on a bastard hi flow .
3)Note the size of the waste gate outlet hole on the T3 turbine housing . Maybe Ok for a dinosaur 70s era 150 Kw T3 but not for any current (in the last 20 yrs) performance engine .
I would rather run your engines std turbo if in good nick than that thing .
A .
well actually its an rb30e+t in an r31 that it would be going onto, but now im thinking ill just keep the 33 s2 turbo on, even tho it may be a bit small for the 30, anyone offer a suggestion of what that highflowed one would be worthe to sell 2nd hand?
It would probably prefer the Hitachi BB VG30 turbos larger OP6 turbine housing if you can find one .
From memory an RB30ET made 153 Kw from its 50 something comp trim small turbine series T3 turbo in 0.63A/R turbine housing form . An RB 25 with the above mentioned turbine housing made I think 206 fly Kw in an R34 GTt .
A .
it appears to be:
.63 VL turbo's turbine housing with a R32's comp housing, bush bearing setup
Standard VL turbo turbine wheel or TB34 turbine wheel with a 8~12 degrees crop running a 56T 71mm comp wheel. It should be ok for about 250~260rwkws on Rb25det with average response using a strong actuator.
Need a none restrictive oil line for Rb2x engines. You will need his dump pipe as the internal gate part is in it.
anyone have any advice on if this turbo would be any good for an rb30et, drove to the dyno the other day (very sedatly), got out and the turbo was leaking oil and smoking. f**k. so im thinking about putting a rebuild kit thru the hi flowed one and putting it on instead before i head back to the dyno, what kind of rebuild kit would i even have to get? or would it just be a mix and match on seals and wheels?
    • Pic of Nos, turbo kit and sequential not loading. 404 not found
    • im sure mine stays in gear and wont shift unless i shift it? and for sure it wont go back to Auto mode if its put in manual mode? if i use paddles but its still in D then of course it goes back to auto mode. but yer if its in -+ and i use paddles it will not auto change gears what so ever and i have tried this. it will gear down if at a stop though which is kinda nice but goes back to 1st gear not D. i think it used to be like this with imports aswell i dunno if its really like it anymore like when i got my R33 it had alot of JDM options which local cars didnt have. Now local cars have kinda caught up even the lower models. but yer transfer rates and other things makes it almost on par.
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
