Items all located in Adelaide, but can post anywhere.
R34GTT steering column cover and cluster surround (needs repainting or stripping off existing paint) $30
R34GTT centre boot badges (Nissan one is a bit scratched buy others are perfect - does NOT include the GTT badge) $30
R34GTT boot lock assembly with genuine key $30
R34GTT heater assembly (NO CORE but everything else works) $30
R33GTR turbo actuators $40 the pair
S3 R33GTR AFMs $50 each
R33GTR genuine Carbon Fibre pod enclosure BRAND NEW $200
R33GTR Cluster showing 20,000km odd - TACHO NOT WORKING (dry solder joint issue common problem $100 to fix). $100
S3 R33GTR coilpacks (were working 100% - upgraded with Spitfires) $150
R33GTR stock FPR $30
R33GTR front pipes $100 pair
R33GTR fuel pump $80
S3 R33GTR injectors $250 for the set
R33GTR turbo oil drains $10 each
S3 R33GTR turbos (NOT N1s) - 1 is fine, 1 has some oil leakage - needs a rebuild. $400 the pair - perfect for high flowing!
MDU (Master Damper Unit) Coilovers to suit V35 coupe. Bought these for $1,100 off Ebay and they are too hard for my liking. They come with both 4kg and 6kg front springs plus 7kg and 10kg rear springs! Too firm for my daily driving taste, but fine for a weekend warrior or track car. One of the rear shockers knocks a bit, but am not sure if it was my install or the actual shock. Fully adjustable front and rear height & damper. Rear springs alone with adjustable mounts are worth this price. I just want to get rid of them, so cheap, cheap, cheap - no warranty offered or implied - did less than 1,000km in my V35, as new (but a bit dirty) $300
I am bit iffy on some of the prices - some may be cheap, some over the top (but I think they all seem reasonable) - I really don't follow the prices too closely. Feel free to make offers, but feel free for me to not even respond to silly offers.
Andrew
  • 3 months later...
Coilovers are sold, all the rest is still sitting here. Someone must need some stock 1997 S3 R33GTR gear!
    • Connected to plenum towards the rear end. Yes, absolutely required for the ECU. Even Nistune can't save you if you don't have it.
    • Can confirm solenoid makes no difference. I finally removed the solenoid and the wire off my engine loom and there is no issue with boost. Keep in mind, this is the solenoid, and I've got a Nistune. After the boost controller, I ran the car for a day with the solenoid unplugged - no issue. So then I just ripped the whole thing out. Like @GTSBoy mentioned before, the ECU just sends an earth signal for the 2-stage boost. And looking at the wire going into the solenoid, that just had 2 standard wires and did not look important 🤣 As for boost sensor: I saw somewhere that the vacuum line the gauge uses is at the back of the engine on the driver side. I never touched that but assume ECU uses that??? (maybe? Just assuming)
    • I still remember it trying to rip the steering wheel out of my hand when I put it into a 4wd power slide lol
    • Im also amazed how well Attessa holds up to all of the abuse. Especially with the burnouts and crap you guys used to do at Texi!
    • True! I think I'm closer to 06 with the cameras in phones being out there more. And the nearly impossible to use internet web browsers. Or paying for ring tones... Man I hated when we couldn't just compose a ringtone on a Nokia anymore! These days I just hate it if my phone rings, beeps, boops, or vibrates!
