Took the car into Midas last week to change the gearbox oil, and also had them check out the exhaust because to me it didn't seem to match what the previous owner had told me. I had been told by the previous owner that it was 3" cat-back only (he didn't do it himself, it was like this from Japan) but I was pretty sure the front pipe was as wide as the bit behind the cat, so I had the guys at Midas measure it for me.
Imagine my pleasant surprise when I discovered that it was actually a full 3.5" system except for the dump pipe, which is smaller and I presume stock. So I've saved a few hundred bucks on the front pipe and high-flow cat because it already has them! Obviously the previous owner had only seen the narrow dump pipe, and the wider bit near the muffler, and assumed it was cat-back only.
My question is replacing that really short dump pipe with a wider one going to make that much of a difference? Midas say they can make me a custom 3.5" Mandrel one to match the rest of the system for around $160, does this sound like a good deal?
https://www.sau.com.au/forums/topic/3566-dump-pipe/
The stock 'dump pipe' (straight off the turbo) is made of cast iron and is certainly worth throwing away. Mine was really badly matched to the turbo outlet, so when I bolted the dump pipe on it was quite noticably better.
https://www.sau.com.au/forums/topic/3566-dump-pipe/#findComment-59226
Originally posted by CMS Drifter
Can u post any pix when you get your dump pipe?
Coz I'm lookin at gettin one when the wallet will allow, but JMS want $350 for theirs.
Where did u get yours from?
Does it have the separate watsegate pipe plumbed back in further down?
Cheers
i am getting mine from arrow diffs in sydney, i was just about to tell them to get stuffed coz its been 3 weeks since i ordered the damn thing, and hes excuse was that the laser cutters was fully booked up and took 2 bloody weeks to get them done!
should be in by next monday!
It has seperate pipe for wastegate that rejoin right before the flange!!
https://www.sau.com.au/forums/topic/3566-dump-pipe/#findComment-62407
INASNT, I'm not sure but I think the guy might have mentioned something about cutting the flange. I'll confirm that with him before I do anything though, don't want a huge 3.5" system running off a 2" flange :D
The pre-fab'd exhaust parts tend to cost more I've found, when I had the Commodore I got a price on a balance pipe and it was about $200 for a special "cross piece". I took it to the place which made my custom exhaust and they charged me about $60 inc. labour for virtually the same thing.
But anyway, I'll find out more before I do anything. Dump pipes are really simple. Provided you have the flange the right size and it's a mandrel bend with minimal or no internal burrs, you only have to worry about the grade of the steel used and what diameter it is.
https://www.sau.com.au/forums/topic/3566-dump-pipe/#findComment-62435
its 304 stainless steel!
there no point going for 316 or marine grade stainless stell as it would crack under the constant heat passing through it
https://www.sau.com.au/forums/topic/3566-dump-pipe/#findComment-62440
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
    • When you say basic rebuild, you mean an oem rebuild?
