What brakes do I have?
Hey, I'm trying to put together a set of R32 Skyline front calipers and rotors. I have the rotors off of a 4 door R32 GTS-T but I'm not sure what model my calipers came off of(GTS or something). Well, my rotors will not fit in between the brake pads in the caliper. The only way they fit is extremely tight and that is when the caliper is open all the way too. I posted some pictures of the calipers and rotor I have here. Please check them out and help me identify what model of Skyline these pieces came off of. Thanks for any help.
You're right those calipers look almost identical to the ones that came off my R32GTS25, the GTS rotor is only 20 - 22 mm so you will have a hard time getting the 28mm GTSt rotors to fit.
what car are they going into??
also the callipars on ebay are the right callipars for gts-t rotors what the thing is is getting them to fit the car you've got and the process involved!!
Hi Zushi,
The calipers you have linked on ebay are exact same as R32
R32 and Z32 same. They are much better than those single
piston things you showed first snap them up if you can
alot easier to start with.
Hey, so those 300zx calipers that I put a link to will bolt on to my S13 front spindle and fit over my R32 GTS-T rotors right?  Let me know.  Thanks.
so you've just put r32 rotors onto a s13 front, i think the only thing to think of is the calliper mounts and the rims you'll be running!
Hey, well I put S14 spindles/hubs on my S13 to make it 5 lug. I have R32 GTS-T rotors, i wanna know if those 300zx calipers will bolt to my s14 spindle? The should fit behind my wheels, I have some 17" OZ F1 rims that came off of an R33 GTR. Think those calipers will work?
 Share
