hey guys i got some plugs and changed my spark plugs yesterday , I was told by mechanic to run BKR7E and regap them at around 0.6mm gap . Now it idles great and doesnt hunt , drives real smooth but when i get it a hit it sounds terrible like a spark breakdown sound around 6,0000 and above . Im running fully built engine with Splitfires and i have never had this issue but then again i have never run that gap or plug before , (always BCPR7ES @ 0.8MM) also now im noticing my 555cc injectors reach 100% without really any load/boost ?
what have i done to my car ? can anyone help me
https://www.sau.com.au/forums/topic/356650-engine-splutter-at-high-revs/
are you running 555cc and Z32 with an untuned PowerFC?
I'm assuming this from your latest thread about idle problems.
If so, it's makes perfect sense why your injectors are smashing 100% and your car is misfiring.
if the injectors are randomly hitting 100% under light load then check your afm wiring. i had a similar problem with the same setup, a dodgy afm wire was randomly earthing out and sending the pfc 5.1v when just cruising along
Yeh it could have that I'll look into it ? Do I just Check all wires are ok and not touching or do I have to pull apart and re solder ? Btw my car is makin 288rwkw and never maxed out past 75% until now . Fixed issue with plugs .. But still 100% duty with no splitterin . Can a slipping clutch cause faulty readings?
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
