post-75119-0-76041500-1299626278_thumb.jpgHey guys
im selling my 96 r33 Series 2 GTST MSPEC
A1 Condition, Interior has no tears and in mint condition, Low KMS, Serviced every 5000kms, Never been on track or strip, Never been boosted stock - 7psi, real headturner!! Dyno'd - 191.8kw atw with only few minor mods.
Best car ever had no major problems ever! Looks and sounds tuff as!
Price - $12500 ono
Milege - 95***kms
Colour - White
Transmission - Manual
Drive - Rear
Engine - 6cyl Petrol Turbo Intercooled RB25
Reg - DIRTI3
12 months rego!!
*MODS*
Body& Wheels
*M-Spec Full Bodykit with Spoiler, also have custom low mount spoiler (will give with purchase too)
*GMax Aspire 18x9.5 Deep dish Mags
*Kumho 265/35R18 - Rear
235/40R18 - Front
*Tyres have 80% tread
Performance
*NIZMO Sports Exhaust from turbo back
*HKS Pod filter
*Blitz Boost Gauge
*Clarion Mp3 Headunit
*Front and Rear NIZMO strut braces
*MOMO Gear Knob
*Carbon fibre handbrake
*HKS EVC boost Controller (Black limited edition, Installed by chasers motorsport)
*GREDDY Front mount intercooler, brand New (Installed by chasers motorsport)
*Plumb Back BOV
*Brand New Slotted front disc brakes with new pads
I have ALL reciepts for every Modification on this car since stock!
Very regretful sale, due to getting married and settling down getting rid of the toys :(:(:( need a 4wd..
Pics below
Cheers guys!!
[quote name=ClutchBurndout-:(' timestamp='1299630086' post='5705593]
what makes it a real head turner?
id say the fact that its not trashed, modded to much, or covered in ridiculous stickers. id notice it if i drove past for those reasons alone :)
good luck with the sale looks nice
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
    • Turbos don't require pulling the motor apart so that's "easier". I would recommend the Nismo R3 turbos instead if you want to do stock twin turbo. It doesn't make as much power as the 2530s but it's only like ~50 whp off the mark and should have better response (ball bearing CHRA, slightly smaller turbo). A local that went with a Garrett G30 and 6boost manifold recently nearly burned his car to the ground after the hood insulator started melting and and burning so if you go single turbo I recommend doing a lot of research and validation work to make sure you don't do the same.
    • New rear lights, filler panel sprayed, cleaned and back together    before, during, after shots 😍
