ive got
hsd fully adjustable coilovers
work 17x8 with bridgestone potanza re01r 235/45/17 front and
17x9 with nexen roadstone 255/40zr/17
cheap rears but they wont last long anyway
305hp atw now on 14psi
chasing 300kw atw
Edited by hooray
Well take about 6% off your power everywhere because they added SAE correction (which ALLSTAR don't usually apply to RWD cars but I'll assume they did it on your graph because you asked for 400hp)... So that's about 380rwhp, then from a hub dyno you loose around 7% on top of that to a roller dyno dynamics so you are down to 355rwhp. So the same power as say a HKS GTRS on the same boost!
Next we will talk about boost response, well it's not really that bad considering the size of the wheels of the turbo (the 0.63 rear housing is helping a lot it seems). About the same as a T67 or a GT3076R 0.82 rear, mind they make about 430rwhp on the same dyno without correction on so the same response as yours but around 50hp more top end!
If you want to compare with my setup I make pretty much exactly the same power till 4000rpm and then a extra 150hp top end (mind you I cheat a little) :)
So in essence you have a turbo that makes the same power as a HKS GTRS with over 1000rpm less response or a turbo that has the same response as a GT3076R but with 50hp less top end...
CRAP!
I agree with what u have said but my safe tune is 18psi for a turbo that should be running 20 to 26 psi. I chose a .63 as I been in .82 and was a touch laggy for my liking. In future I will change to a .82 with more boost and aim for big hp.
fair enough but ideally you should be running a smaller gt30 with a larger (1.06) rear housing to get the same sort of power with better response and less stress on the engine (those .63 housings arent great for cylinder scavenging and temps). it'd also come on boost much smoother than the .63 gt35, making it much easier to control wheelspin.
    • If you do go with drain back, make sure everything is foam or wool filled so it actually does something, and ensure there is a screen somewhere in the drain to catch anything that comes loose from the packing. I don't drain back
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
