As title says, brand new in box Blackberry torch 9800. Great phone - touchscreen and blackberry QWERTY keypad.
$500 - no offers. email [email protected]
Can be picked up in Sydney or post at buyers expense.
Thanks,
Anton
https://www.sau.com.au/forums/topic/356696-blackberry-torch-9800/
