  • Replies 124
Wel my tips are in for the first time in a few races. My tip is this is the first time this year that Vettel comes undone. Webber finally gets the job done and makes up for his backflip last year....so Webber, Button and Alonso are my top 3.
PS...i will continue to put Webber down for a win until he gets his first race win of the year :) Will hate myself if he gets up when I am not backing him...and if I have to wait to Jungary when I will be there and able to throw DJ rocks at his competitors
lol, what about the time I challenged vettel to a fight in the carpark at monza!? at least my voice can be clearly heard above those mincing italians. he looked scared I reckon when I heckled him... it made going to monza worthwhile! that at the gypsys in the carpark doing card games.
This week is my week :)
Race winner
Mark Webber
Podium finishers (top 3, position irrelevant)
Mark Webber
Lewis Hamilton
Fernando Alonso
Points finishers (4th - 10th, position irrelevant)
Jenson Button
Felipe Massa
Michael Schumacher
Nico Rosberg
Rubens Barrichello
Paul di Resta
Kamui Kobayashi
Fastest lap
Sebastian Vettel
Come on, 5 points to the lead;
Player: N1GTR
Pool(s): Red Bull Fans, SAU
Race winner
Sebastian Vettel
Sebastian Vettel
Mark Webber
Lewis Hamilton
Jenson Button
Fernando Alonso
Michael Schumacher
Nico Rosberg
Nick Heidfeld
Kamui Kobayashi
Sebastien Buemi
Fastest lap
Sebastian Vettel
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
