  • Replies 95
I've corner weighed plenty of skylines.
Every one of them varies but on average an r33 gtst's come in around 58%front heavy
R33 GTR's are typically 62-65% front heavy.
Comparably a 32 gtst is 56-60% front and a GTR 58-62%.
Most of the cars I've done vary in trim level, cages, body mods etc so it's pretty hard to get an accurate average.
Cheers for that :)
So going off that 58%, say a R33 GTST weighed 1400kg, it would take moving around 112kg from the front to the rear of the vehicle to get close to a 50/50 weight distribution.
Or removing 224kg from the front to get close to a 50/50 weight distribution.
Or obviously a mixture of moving and removing.
Crazy. Makes you really see how front heavy they are.
Fairly standard R33 GTR Vspec
FR: 430kg
FL: 447kg
RR: 360.5kg
RL: 331kg
Total 1568.5kg
Cheers for that :)
Remounting stuff goes a long way to helping without actually removing that much weight from the car.
Moving weight around on a set if good scales has the greatest benifit.
Typically if building a car from scatch it will permanently be sitting on scales.
I have been doing an s15 recently which has always been on the scales so things can be located once and properly.
The height various components are mounted is just as important as their location if your worried about a front to rear center of gravity height and roll axis as well.
Corner weighting via ride heights with a purpose built race car should be done after the car is statically balanced with weight.
Just for your info my r33 gtst stripped out and caged weighed in at 1374kg on the scales at EC. That is with a full tank of fuel and all factory body panels. I am very keen to get it down to the mid 1200's.
:thumbsup:
Mike was your car weighed with driver and full fluids?
Just curious
Full fluids with 3/4 tank of fuel. No driver... would have been a lot worse we me in the driver seat, you have seen the state of me Brad, lol. I think if you could get at least 100-150kg of weight out of the R33 GTR in the front half of it it would make a lot of difference.
Good to chat with you Fineline, cheers mate.
  • 1 month later...
Just put mine on a set of corner weights. Striped interior and of stock loom. Driftek 17/9.5 GTR off with 235/45 Kumho V70A glass bonnet all other pannels std (Drivers door has no insides at all though) And 1/2 tank of fuel.
Cross 613kg 50.3%
Left 613 kg 50.3%
rear 511 kg 41.9%
LF 353kg RF 353kg
LR 260kg RR 251kg
Total 1217
I need to re do it with me in it yet, but is a starting Point.
I have 10kg to come out of the pas door and a set of light kevlar Guards to go on..... looking for 1280 full of fuel and with me on board.
Edited by Noddy
I am also trying to put my car through the Jenny Craig program and this threads been great but this will be a silly question to most of you but where would I go to weigh my car? lol How much will it cost?
Also would taking out the side rear air bags be illegal for a road registered car?
Edited by Bourbon Boy
Taking out any factory airbags is illegal in most states (most likely all). Also as far as I am aware, disconnecting just one airbag in a vehicle with multiple airbags makes the rest not work.
Any good workshop that sets up race cars should have calibrated corner weight scales.
If you just want an overall weight a public weigh bridge will do. I took my truck over one today was $22.00
If your in Sydney and want to know individual weights I can help you with that.
weight your car at a garbage tip for free, if you are near a tip that uses weight to charge for rubbish, drive in turn around and come out...no weight change no cost... lol...
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
