  • Replies 95
so how do you drive backwards in the rain phil, sounds kinda dangerou
Whoa.... talk about off track thread!
This is about getting a 33 GTS-t to 900kg guys, lets be serious can we.....
I think you'll need to use GTR front guards.
just remove the guards altogether , not like they are doing anyting useful
Thanks for all the replies . I have read them all. Interesting and helpfull. The car has been stripped of interior parts and has no seats or carpets, sound insultion taken out. Have the sprint v seat ready to go in with harnesses. The air con will be removed next. I am considering putting a carbon fiber bonnet on after the air con removal. I believe these can save approx 8 - 9 kg. after that will remove sound deadening from boot, few extra interior parts to go. BTW how much will the air con on an R33 weigh? how much weight would aluminium radiator save?
Took the aircon out of my 32 the other day, everything in the engine bay came to 14.9kg.
Aluminium radiator weighs a similar amount to the standard plastic one, how ever the larger size means it will take more coolant and thus increase the overall weight.
i saved around 8kg in doing the rear quarter and windows lexan. thats in a 31 though.
if its track only how about
fuel cell
removing hicas +all lines
titanium nut/bolts +wheel nuts
rotor with alloy hats
bonnet boot and doors in carbon
smallest wheels your brake will allow (i think you save around 1kg a tyre a inch)
alloy/titanium pipe work
etc etc
maybe even going something like a LS1/X/2 or VQ35DE+t lot of weight saved in alloy blocks and ive seen a dude pick up the 6 speed out of the VQ35 under one arm!
depend on how serious you are i suppose.
does the R33 have the same plastic fuel tank in between the spare tyre well and the rear seat the same as the s14/s15? If so fuel cells difference can not be as great and where i have seen most people place them is higher in the centre of gravity.
As I see it, the front of gtst's is where most issues are in terms of easy weight to remove.
frp bonnet and guards are a no brainer. I have made an mould and pulled a set of Kevlar guards out, <1kg each. Front bar with splitter is still in the works.
Eliminate all the normal comfort stuff, sounds like you have done most of that.
The windows, reg etc in the doors saves 20 kg on its own. Trimming the extra fat off the steel door ends up lighter than carbon ones I have weighed.
I have seen an s14/15 strut front end in a 33. I question if the weight of a loaded car will flex the strut, but I am looking into this over the next week.
I think close to 1000kg is realistic and possible, that's where I'm aiming, I'm building it for 2A Sports which has a min wieght restriction. I'll be under so this way I can choose where it goes to balance it all up nicely on the scales.
Photos of front bar? :)
Also while on this topic, does any one actually know the weight distribution of Skyline models? (As in 60/40, 55/45 etc).
Has any one weighed one properly? How much weight from the front has to be removed (or moved to the rear) to bring out a better balance towards 50/50? (obviously would be very hard for a GTR with the extra weight over the front axles).
2nd pic from the top shows it. This is not suitable for a street car, it sits way too low.
Theres another pic further down that shows just how far the splitter protrudes.
track car only.
http://www.boostcruising.com/forums/index.php?showtopic=713232
    • For your application, where you'll be at that 1/2" size or perhaps larger, yeah, excellent. Although not if you need a tight bending radius anywhere, because the corrugated stuff is not anywhere near as flexible as rubber/teflon cored stuff. But for turbo oil lines? No. Too big. They just don't do the corro stuff down at the ~1/4" ID size that you'd want, and if they did the OD of it would probably be a bit too fat for fitting it into the tight spaces available. I use hoses like that all the time for fuel gases (LPG, NG) and liquid fuels (HFO, diesels, waste oils). When we did the London Olympic cauldron, with the 204 individual burners on it, we had miles of the stuff (although a lot of that was teflon core). A bunch of that crap is still cluttering up the workshop, more than 12 years later!
    • Would something like this be an option  https://processhose.com/products/configurable-metal-hoses/1-2-in-t316-stainless-steel-annular-corrugated-configurable-flexible-metal-hose-assembly-with-ends-t304-single-braid-masterflex-af5550.html I'm looking at this for replacing the OEM EGR when installing a aftermarket intake plenum
    • The once piece tail shafts with cv type joints on either end are the ones that end up vibrating and the vibration is caused by the cv joint binding as it turns, I’ve also seen them explode from the binding
    • Take this with a pinch of salt, it's from someone (me) who got annoyed with turbos entirely. I hated aftermarket lines. If I had the option to use hardlines with whatever turbo I had - I would use them, 10/10, 100% of the time. The only reason people go larger, heat resistent, shielded lines etc is because they have to. And yes they don't last forever. Even if you spend big bucks on all the best heat shielding money can buy, with the best heat resistant, fuel resistant, oil resistant, radiation resistant hose, they get stiff and break down and just don't last the way a metal pipe will.
    • Unfortunately I am quite literally halfway across the globe. So all sources for parts like that are far away for me. What do you mean by that exactly?
