Hey guys I'm just wondering if any of you have done this. If so I want your opinion. I was thinking putting a relay on the headlight switch earth lead and attach the magnetizing coil to the on position of the ignition switch. Is this the correct way to go about this or is there a different way
Thanks
Possibly cut the power supply wire and run it from an accessories power source.. So you only have power to the indicator when the ignition is on.. I'm not an auto elec so you'd need to confirm the load is ok if you was to do this..
I'd rig the headlight switching wire into another relay that only switches with ignition power, ie you need ignition on and headlight switch on to run lights, as you don't want lights on all the time with the ignition correct?
I've thought about doing this as I always forget to turn my lights off on overcast days.
I would just do what Craig said and instead of the headlights having a constant 12V source wire it up to an accessories 12V.
Also be aware that in rare cases you may want your headlights on without the engine on...better off making a seperate switch and relay for the headlights altogether...that way you can toggle between auto off/on and manual off/on modes.
yes but if you run the stalk source to the accessories.. that "should" mean that you won't have power to the stalk until accessories (ignition) is on.. but lights shouldnt come on until you activate them from the stalk..
tried to think of this but that would ultimately defeat the purpose of the auto off.. if you can have both auto off and manual on.. how will the car know that you infact want them on if the car is off? Unless you run it on an override switch.. So switch in position one = auto off.. switch in position 2 = manual override..
if you don't understand these try and find an auto elec to do this please.. fiddling with elec and you don't know what you are doing = bad outcomes..
I don't know...I'm not that familiar with electronics themselves, just the semantics and basic maps. Was mimicking the Soarer setup, which goes: Parkers, Low Beam, Auto. Switching between Low Beam and Auto flickers the lights for a split second, so I imagine headlight power is diverted through a different circuit when on auto. Also, auto off occurs when the driver door is opened rather than the key in the ignition...so it must run off the doorlight switch circuit.
Complicated stuff!
i only used my timer for a month then used to put it in top gear last minute or two as i approached destination. but good point phil its been so long id forgotten it doesnt work while on timer
    • I know mentally you're set on the ATS clutch but honestly I'm a big fan of the Nismo Super Coppermix Twin. It's much cheaper and in some ways I think it's a better design for a street/circuit car.
    • Just checked in first post and you should be able to bring it home November this year, right? I'm amazed you made it through four years of this. As hard as it feels now the rest will go by in a breeze in hindsight, I'm sure.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
