1992 Nissan 180sx
SR20DET - Red Top
Turbocharged
5sp Manual
Grey
170,XXXkms
Engine/Gearbox/Driveline in Perfect Condition. No unusual noise/crunches/leaks etc.
Autotechnica Steering Wheel
New Stainless Steel Gear Knob
S14 Front Seats - Near New Condition
CD Player
Brand New Performance Front Indicators
Dash has a slight crack
Full Tein Coilovers - Height & Camber Adjustable
Full Exhaust
New Pod Filter
Aftermarket Side Skirt
Aftermarket Rear Bar Lip/Pods
Tyres in RWC condition
Does not need anything for RWC, as far as I can inspect.
No Rego/RWC
After a Cash Sale
Sorry NO SWAPS
PLEASE - NO OFFERS UNTIL YOU'VE SEEN THE CAR
Anything I haven't answered, SMS me (0423893095)
Selling for someone else.
$6500
