Just wona know what people have used under thier car when working on it at home to stop stains on the ground.
im going to be doing,
timing belt replacement
removing turbo
manual convertion
on my skyline and the old man is fanatical about cleanliness, even when i did the turbo change last time some coolant got threw the tarp and slightly stained.
Did manage to remove it.
just wonding if thier is any other ways out thier?
https://www.sau.com.au/forums/topic/356762-what-have-u-used-on-the-ground/
removing turbo
manual convertion
Chuck a tarp or thick plastic down, then a carpet remnant on top.
Carpet soaks up any big spills before they get to the tarp & go through any small tear or holes.
They're cheap as chips from your local carpet supplier, they've always got a few metres of some ugly arse carpet hanging around.:thumbsup:
i roll out a piece of vinyl floor covering. its easy to clean so you can re-use it. its thick-ish so it always rolls out flat and its easy to slide under the car as well as pull yourself back out.
Im a big fan of the cardboard box...
a) im ghetto and never think about those things before i start working on something, so usually have a cardboard box lying around
b) they soak shit up
c) kinda comfortable in a weird S&M kind of way
d) put them out for recycling when done
:D
I agree with the cardboard box!
Go to a panelbeater and ask them if they have a bumper box lying around. I had a huge Ford box for a year or so before it was too stained to go on. Fold them out and they will nearly cover the entire floor under the engine :)
they also have rolls of carpet in the bin. just look for some vaguely clean stuff. jacks and creepers don't roll on carpet or cardboard very well. go the vinyl if you dont mind buying some, or can find some old stuff. try carpet place again, they should have something. depends how much of the floor you want to cover i guess.
  • 3 weeks later...
If I need something bigger than my cut-down-office-water-cooler-bottle oil drip tray, then I've had too much to drink and shouldn't be under a car. Wanna know what keeps my garage floor clean? Skill.
lol
What you need is a product called flotex.
It is a short pile waterproof type of carpet used predominately in hospitals, nursing homes, kindergardens etc. Anywhere there could be spillage and needs hot water to clean it etc.
It has a synthetic rubber back and will let nothing through. comfy to crawl around on too.
Just hose it off to clean it as water has no effect on it.
And yes, I am in the trade.
Here's another random one, bunnings sells some floor protector mat stuff (in flooring section), comes in a big ish roll, its about 10mm thick rubber/foam stuff and has a sweet checkerplate pattern -> lol. also pretty cheap. Just another option if you don't want a bruised back from rolling around on concrete :/
    • At SMSP, I mainly see Hondas, M cars, A90 Supras and of course, plenty of Evos. Have not seen a single R32 ro R34 Skyline on the night sessions that I've been to. That's really saying something.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
    • I specifically said buy new performance car because of the use case here (i.e, no track use and fun livable everything/do it all easily if not especially amazing as a drivers car). Tracking an 80K Skyline and an 80K M2 makes the BMW the obviously more risky purchase WHEN something goes wrong you suddenly can't easily fix it with hand tools and readily available parts that you may have a community of people you know available, or years of your own knowledge on the platform to apply. There's reasons you see Hondas and Vettes and RB's and Miatas and such at tracks, you can easily hand-tool repair 99.9% of it in a shed, usually with the tools and the skillset of the owner to apply to it. An i30N is not going to beat a R chassis unless it's got massive problems either. The old cars can, and still do work great. The problem is - and always has been - social media would have you believe it's simple and easy to achieve the results you see online.  People want their car to be like "one of those cool JDM cars" which is the default image people have when they think of  "cool JDM cars" You are paying 25 years of catchup R&D to achieve. Or the knowledge somebody else has to do it for you, which is big dollar restomod stuff.  The bar has been moved and every R chassis that people see/like/enjoy has 25 years of R&D thrown at it, or is owned by someone who did all that work and has that knowledge over the past 25 years. All the survivors have been progressively resto-modded the entire time. OR you slowly bring it back to how it was stock. Which is also prohibitively expensive, done for the love of it. This is what the JDM community is now. This is fine, but "Where do I start?" is either: 1) Don't 2) Take your own slow journey but you cannot compare your progress with others who have had 25 years of R&D and experience building their own cars unless you pay for it.
    • Yep, with the crazy inflation of the value of our cars these past couple of years this became a problem for me too... My solution is to transition to bikes. Everything feels so cheap compared to tracking the skyline lol
