hey
the other day i made a phone call to CES (Custom exhaust systems) and they told me that an R33 gtst skyline has stock 143kw at the wheels. they than told me that they have an exhaust system worth, $1900 that will give the car dyno proven 180 to 188kw at the wheels, and after that installing a kn or decent air filter, and turning up the boost to around 11 or 12 they can produce up too 200rkw, do u think this is true, because they say they have dyno proven results and if it is than the car would have to be pushing high to medium 13 second times, wouldnt u think? can someone shead some light on this topic becasue im sure if its true than alot of poeple will want their exhaust.
https://www.sau.com.au/forums/topic/35678-what-mods-too-do/
CES are very good, the only complaint I have heard of is the price, but as the old saying goes "you get what you pay for". And I think in this case from what I heard its true. Dunno about there power increases though, 200 rwkw could be achieved with their list plus a decent intercooler and aftermarket ECU (powerFC). 200 rwkw without even a SAFC seems a little far fetched to me, I am pretty sure around the 200rwkw mark is limit for standard turbos anyway, give or take a few. Depends on the condition of your engine also, so many variables!
https://www.sau.com.au/forums/topic/35678-what-mods-too-do/#findComment-712231
would you stop f.ucking stop double posting everything you want to say on here on different sections, and in different posts?!
...kind of annoying, and its not going to get any better response. In fact you'll probably get less so because it shits people.
https://www.sau.com.au/forums/topic/35678-what-mods-too-do/#findComment-712233
Generally speaking for a 33, and gauging by other members results, would I be wrong in guestimating this?...
130-135rwkW - Stock
140-150rwkW - Full 3" Exh & Air filter
160-180rwkW - Full 3" Exh, Air filter/Feed/Partition, FMIC, 12PSI, Fuel Pump, SAFC.
180-200rwkW - Full 3" Exh, Air filter/Feed/Partition, FMIC, 12PSI, Fuel Pump, SAFC/PowerFC, Exh Cam Gear.
https://www.sau.com.au/forums/topic/35678-what-mods-too-do/#findComment-712690
interesting results...
i would assume that 40kw increase is not at the wheels
intercooler, 3in double dump and increased boost from the higher flow would probably give 200kw
$2000 would almost get you a intercooler installed and maybe a catback exhuast, id spend the extra 500 and get the double dump and finish off the rest of the exhaust at EXOTIC EXHAUST.
https://www.sau.com.au/forums/topic/35678-what-mods-too-do/#findComment-717012
130-135rwkW - Stock
I doubt you would be able to get a GTST into a true 200RWKW without changing the turbo, and if you could it is just a matter of time until you need a new turbo anyway.
https://www.sau.com.au/forums/topic/35678-what-mods-too-do/#findComment-717017
definintely not something that would last or recommend however what i suggested would be the absolute minimum to get even close to 200kw
sorry if i mislead n e one
https://www.sau.com.au/forums/topic/35678-what-mods-too-do/#findComment-717305
i dont think it would be hard to crack 200rwkw on the stock turbo. I got 181rwkw atm with the mods in my sig on 10psi, and i reckon with a exh cam gear and 12-13psi and a bit of tuning would get me 200rwkw. The turbo is fine at the moment i dont see how an extra 20kw would kill it. But i do agree that it will reach its "safe" limits then and i will look into highflowing.
https://www.sau.com.au/forums/topic/35678-what-mods-too-do/#findComment-717708
    • Dang. I love the little 'oil used' bingo card on the side.   🤣  Well, now they can use a box and an oil-filled goon.
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
    • The main stuff from.Vibrant I see is more their intercooler piping, and everyone raving about their clamps, but when I looked it was about $150 per clamp... I was a bit   I also thought the public price SP had up was high. As Mark said, a normal exhaust shop can fab them. It was many years ago that I had a full exhaust built, but for a full turbo back exhaust, and 2 custom built mufflers, plus a high flow cat, was about $1,100, and that was fully installed, drive in, drive out. I believe SP was about $900 for 2 mufflers, just supplied   These days, I just buy the material and built it myself, because I need to stretch my $$$
    • I'm pretty sure if it's considered a gasoline powered vehicle you have to do certification against a fixed, very expensive certification fuel.  If you add two precats and then replace the main cat with two cats back to back you can get an RB26 to do 0.24 g/mi HC, 1.6 g/mi CO, and 0.3 g/mi NOx on the FTP-75 drive cycle. Found this out courtesy of California's laws at great expense. Divide by 1.61 to get g/km. So even with extra cats + precats you're blowing past the NOx limit by probably 2.3x. Probably the only way to get an RB25 or RB26 to meet euro 4 purely from an emissions per km standpoint and not durability/OBD2 requirements is retrofit at least intake side VVT, clearance the pistons to allow the full 50 degrees of advance so part throttle EGR can be maximized, and change the wastegate control from conventional 7 psi spring for example to one that is always fully open if the wastegate line is at 1 atm or higher and only close it in response to vacuum. See BMW's N54 engine as a reference for how this works. You would need to find space for a vacuum tank to function as an accumulator in this system. That way you can avoid any heat loss to the turbine as much as possible during cold start to heat the catalyst faster. Then find some way to eliminate as much as possible cold start enrichment to light off the catalyst rapidly. Maybe secondary air injection if there's no way to avoid cold start enrichment. Close coupled catalysts in the downpipe are probably necessary. I would also probably swap to EV14s, pick something with the correct spray targeting + dual cone pattern for the intake manifold you're using. EV1 style injectors to pass anything resembling modern emissions requires a very annoying air assisted injector system to break up the droplets at part throttle/idle which still doesn't work that great compared to just having smaller droplets from the injector to begin with. Realistically, you're probably going to be financially ahead if you just pay the fines instead. Or don't drive it into the city center. There's a reason why Nissan never bothered to even attempt certifying an RB for CA/US emissions. The VG30 needed external EGR on top of NVCS to pass in the 90s. Doing all of this work is also distinctly expensive and you're going to struggle to find anyone who is remotely interested in helping.
    • I remember those, people use to steal them to make bongs.....
