Hi everyone,
We are currently looking for a senior .NET developer (3+ years experience) and I thought there might be a tech savvy SAU member interested in the position,
The role will consist of prodominanty .NET development in the online space however experience with Sitecore/ OpenText CMS would be really handy. The position is based in the Melbourne CBD and you'll be working with a friendly bunch of people with skills ranging from technical through to front end design. You can check out some of our work here
If this sounds like something you'll be interested in, feel free to shoot me a PM or leave a comment,
Position Tweeted here --> Linky
Cheers,
Sean
Any graphic design position open? :P
Hey mate,
There isn't a specific graphic design job going at the moment however if you have skills in front end technologies including HTML5, CSS3 and Javascript, there's a job in the creative pod currently available
I can PM you more details if you're interested?
Cheers,
Sean
any accounting positions available, first year uni student :P
Hey mate,
Nahh sorry, you'll have to finish up your degree first :happy:,
Best advice I can give you though is to jump on some vacation work if your uni provides it, makes it a really easy transition into a graduate position if you have a few weeks work experience over the rest of the crowd :thumbsup:
Cheers,
Sean
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
