Full Time Position Available: Deloitte Online
I thought about ditching it but I was worried my bonnet would sound like a 90's Swift GTi sub-filled boot.
Have you found that you have to tighten your alternator belt once in a while? Mine has started to squeal again after the mechanic tightened it roughly a year ago and the engine starts up slow if I don't start it every day (think the starter motor is going out). It used to be if I don't drive it once a week I'd get a quick squeal on the belt but now it's every day or every other day. I might make a post of the start up sound.
I spent the entire of the long weekend going through my garage and I'm now, after 3.5yrs in this house, able to fit a car in. The garage is quite long and the back half has a high enough ceiling for a 2 post lift but it's going to just take too much space and I don't think I'd be able to get around the car if it was in the air. So, in comes the quick lift. It looks perfect. High enough to do most things, I reckon even getting a gearbox out would be doable. Does anybody here have one? They're fairly cheap (~$3k) considering... https://www.dtmtrading.com.au/product/quick-lift-portable-vehicle-hoist-3500-kg-worksafe-approved/ I'm also a bit of a non risk taker so I'd probably still use stands when under!
Well now we all see it! I did the same. Then cut it out. Then melted half of it. Then discarded it entirely. So... you're in good company.
I just replaced the god awful, sagging, crunchy bonnet insulation. It's something nobody but I see but it's been at me for a while.
