Hi i have the followings up for sale:
Hypergear ATR43G3 .63 rear turbo
direct bolt on for r33 gtst. comes with high pressure actuator.
put the turbo on last year late November. I left the country for 3 months since then so the turbo has seen literally less than 5000km's
The turbo is still on the car will pull it apart when deposit is paid.
$900
Apexi PowerFC to suit r33gtst both S1 and S2
No handcontroller.
cant get the serial number it is still running on my car so its 200% working
has been tuned with above turbo and z32afm.
$900
R33 GTST S2 boot spoiler in white
$50
KTS Japan Steering wheel with bosskit to suit R33GTST
$160
All items are in Melbourne can post at buyer's expense (spoiler excluded)
contact details: reply here // pm // [email protected] // 04 6886 0911
https://www.sau.com.au/forums/topic/356812-r33-gtst-parts/
hi turbo is internally gated. the turbo is almost new (<5000km's and only been driven on the street , never seen rev limiter) but its still on the car so I cant exactly comment on the shaftplay but i would expect none since its basically new.
its rated at 280~300rwkw (~500hp).
cheers
https://www.sau.com.au/forums/topic/356812-r33-gtst-parts/#findComment-5707876
thanks for the kind words.
sorry for the delay at the workshop tho.
wheel and boss are sold too.
still got:
r33 s2 spoiler (white) $30
2 x works 3" to 2.5" silicon reducers $20
also a z32afm in working condition just got it off from the car today
as shown in the photo theres a crack at the side of the AFM cover but doesnt affect its performance.
it has been in good working condition till the second its taken off.
ill also throw in a 3" intake hard pipe with the z32 to suit r33 RB25.
$200
https://www.sau.com.au/forums/topic/356812-r33-gtst-parts/#findComment-5726146
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
    • Dort sounds above 3k rpm are dorty 🤣 I might krinkle black the alloy 🤔
