Hey,
Did the headlights survive? If so, are they the Xenon ones?
Cheers
Headlights did not survive, broken mounts, were xenon ones. Thanks
  • Replies 55
As requested, here are the pics.
Sold so far:
Rear wiper motor
Centre console trim around shifter
Front seats
Reverse lights
Sideskirts
Front interior light
Head unit trim surround
Centre console lid
Front indicators
Side repeater indicators
Radiator shroud and bonnet strut
RH taillight
Sold so far:
Rear wiper motor
Front seats
Reverse lights
Sideskirts
Centre console lid
Front indicators
Headunit
Boot/fuel cap cable
B pillar external trims
Edited by griffonfamily
hi,
how much for the two bits of trim circled in the below pic, as well as the big bit of plastic/trim that has the arrow pointing to it?
thanks.
hi,
thanks.
The centre console trim (arrow one) $30 without the centre console lid. Sold the circled pieces tonight.
Sold so far:
Rear wiper motor
Front seats
Reverse lights
Sideskirts
Centre console lid
Front indicators
Headunit
Boot/fuel cap cable
Interior rear view mirror
Gearknob
Headlights
Strutbar
Din pocket
Circled plastic trim next to headunit
Kick trim inside the door jam
bonnet heatshielding
hey ed, now that ive got the front seats in my car i kinda want the back ones now lol. how much do u want for them?
$50. The rear base has a couple of cigarette burns though :(
Sold so far:
Rear wiper motor
Front seats
Reverse lights
Sideskirts
Centre console lid
Front indicators
Headunit
Boot/fuel cap cable
Gearknob
Headlights
Strutbar
Din pocket
Climate control unit
As requested pics:
$50 for the pod filter. Thanks
Can you post it to 3152? Dont have time to drive around lol. Will be happy to pay postage costs.
I might wait to see if i can find some in better condition but if i cant find anything i'll let u know
$55 posted. Thanks
Sold so far:
Rear wiper motor
Front seats
Reverse lights
Sideskirts
Centre console lid
Front indicators
Headunit
Boot/fuel cap cable
Gearknob
Headlights
Strutbar
Din pocket
Passenger mirror
Exhaust from catback
Steering column trim surround
Sold so far:
Rear wiper motor
Front seats
Reverse lights
Sideskirts
Centre console lid
Front indicators
Headunit
Boot/fuel cap cable
Gearknob
Headlights
Strutbar
Din pocket
Passenger mirror
Gauges
Exterior black trim above front doors
Sold so far:
Rear wiper motor
Front seats
Reverse lights
Sideskirts
Centre console lid
Front indicators
Headunit
Boot/fuel cap cable
Gearknob
Headlights
Strutbar
Din pocket
Passenger mirror
Gauges
Drivers side mirror
Gearbox
Clutch
Flywheel
Tailshaft
Spoiler
Clutch pedal and slave cylinder
Full set of floor mats available $50. Thanks
hey mate how much for the front seat L&R do you got genuine skyline floor mats???? how much can you post to DARWIN NT 0810???
cheers....
    • In the context of cam 'upgrader' I mean generally people who upgrade headers/cams - not my specific change. I mean it makes sense that if I had a bigger cam, I may get more false lean readings. So if I went smaller, I'd get less false lean readings. To a point where perhaps stock.. I'd have no false lean readings, according to the ECU. But I'm way richer than stock. My bigger than normal cam in the past also was giving false rich leanings. It's rather odd and doesn't add up or pass the pub test. Realistically what I want is the narrowbands to effectively work as closed loop fuel control and keep my AFR around 14.7 on light sections of the map. Which is of course the purpose of narrowband CL fuel control. So if I can change the switch points so the NB's target 14.7 (as read by my WB) then this should be fine. Haven't actually tested to see what the changed switchpoints actually result in - car needs to be in a position it can idle for awhile to do that. I suspect it will be a troublesome 15 min drive home with lots of stalling and way too rich/lean transient nightmare bucking away for that first drive at 2am or whevener it ends up being. Hopefully it's all tune-able. Realistically it should be. This is a very mild cam.
    • Messing with narrowband switchovers is a terrible bandaid. I don't want to think about it. You are a cam "upgrader" only in concept. As you said, your new cam is actually smaller, so it's technically a downgrade. OK, likely a very small downgrade, but nevertheless. But the big thing that will be the most likely suspect is the change of the advance angle. That change could be equivalent to a substantial decrease in cam lobe duration. I haven't gone to the effort of trying to think about what your change would actually cause. But until someone (you, me (unlikely), Matt, someone else) does so and comes to a conclusion about the effect, it remains a possibility that that is the change that is causing what you're seeing.
    • The previous switchover point was 501mv. The stock value is like ~360. They now were idling at about ~880. The thing is, most people get a false lean condition. I am getting false rich conditions. This isn't a quirk of terminology, most cam upgraders get awful fuel economy because the O2's read false lean and add fuel - Mine are attempting to aggressively subtract fuel.
    • So... the whole idea was to upgrade the power of the motor from stock. The motor I bought with the gearbox had 'some' stuff done to it in the past, but it wasn't as well thought out/what I had wanted to do. The stock heads typically are a big restriction on LS's and need porting to unlock quite a lot of power. You can then go a bit silly with aftermarket castings to get more, aftermarket intake manifolds for a little more, and then porting those for more. <- We are here. Nobody in Australia really goes down this path (for some reason). It might* make 3kw or something more than doing things the tried and true path for 10X the cost. So that's probably why - I wouldn't even recommend it to people, the money was and is likely better spent on just CNC'ing the stock heads and putting a 6.3L stroker kit in. I didn't want to go down the 'normal' path and then think: But if I'd just done a bit more - I could have had a slightly better result. I assumed the heads were running out of flow and it always annoyed me - Turns out the previous installer advanced the cam 6 degrees so this is likely why it was coming on earlier and running out of puff earlier than advertised. The body panels were just lack of planning/no information on this anywhere on the internet and the fact they came out different was annoying. From test fitting the guard it appears I could have gotten away with GTR guards only, but I got the bonnet and raisers and everything else as well for a pretty decent package deal.
