  • Replies 55
Still have the shell but what are you chasing it for? The front rad support panel has been cut out though. Give me a call if you are interested. Thanks
Complete rb25de neo engine 2.5 vvti 150 kw with all ancillaries less flywheel and starter, with engine loom and computer $900. Only done 102,000 ks, in good condition. Pick up only from Frankston area. Thanks
Items Sold so far:
Rear wiper motor
Centre console trim around shifter
Front seats
Reverse lights
Sideskirts
Front interior light
Head unit trim surround
Centre console lid
Front indicators
Side repeater indicators
Radiator shroud and bonnet strut
Headunit
Boot/fuel cap cable
B pillar external trims
Interior rear view mirror
Gearknob
Headlights
Strutbar
Din pocket
Circled plastic trim next to headunit
Kick trim inside the door jam
bonnet heatshielding
Climate control unit
Passenger mirror
Exhaust from catback
Steering column trim surround
Gauges
Exterior black trim above front doors
Drivers side mirror
Gearbox
Clutch
Flywheel
Tailshaft
Spoiler
Clutch pedal and slave cylinder
Windscreen washer bottle pumps
Drivers and passengers side window regulators
Complete rb25de neo engine 2.5 vvti 150 kw with all ancillaries less flywheel and starter, with engine loom and computer now only $850. Only done 102,000 ks, in good condition. Pick up only from Frankston area. Thanks
Make me offers on any stuff thats left guys, the rest of the gear will be going on ebay soon
Items Sold so far:
Rear wiper motor
Front seats
Reverse lights
Sideskirts
Centre console lid
Front indicators
Headunit
Boot/fuel cap cable
Gearknob
Headlights
Strutbar
Din pocket
Passenger mirror
Gauges
Drivers side mirror
Gearbox
Clutch
Flywheel
Tailshaft
Spoiler
Front guards
Aircon lines
Front shocks and springs
Here is a price list and some pictures of the stuff left that is still for sale:
Rear subframe with diff,driveshafts and hubs $200
Rear calipers $50
Front calipers $50
Overflow bottle $20
Apexi pod filter $30
Fuel pump and tank $70
Windscreen washer bottle $15
Headlining $30
Door trims $50 ea including switches
Door actuators $70 pr
Steering wheel $40 (has quite a few marks but no major peeling)
Steering wheel airbag $100
Dash including passenger side airbag $120
Engine fan $40
Rear trims $50 pr
Rear seat $40 (has cigarette burn in base)
Heater core assembly $50
Aircon and fan assembly $50
Seatbelts $50 ea
Centre console trim $30 (without centre console lid)
ABS unit $80
Rear tail light $80 ea
Carpet $60
Brake master cylinder and brake booster $70
Power steering lines $50
Front part of exhaust to end of cat (including near new cat) $50
Genuine Floor mats - set of 5 $50
Wheels with good tyres $150
Rear shocks and springs $50
Handbrake assembly and cable $40
Front hubs $100
Front discs $40
Rear discs $40
Front cross member and rack and pinion $80
RB25de neo Engine including loom and computer $850
Starter motor $50
Steering column with key $50
Door, with glass $150 ea
Fuel door/flap $20
Heaps of other trim parts and stuff available - just ask 0422641010. Parts located in frankston, Vic. Prefer pickup.
Items Sold so far:
Rear wiper motor
Front seats
Reverse lights
Sideskirts
Centre console lid
Front indicators
Headunit
Boot/fuel cap cable
Gearknob
Headlights
Strutbar
Din pocket
Passenger mirror
Gauges
Drivers side mirror
Gearbox
Clutch
Flywheel
Tailshaft
Spoiler
Front guards
Aircon lines
Boot carpet and board
Rubbers around doors
Rear boot trims
Items Sold so far:
Rear wiper motor
Front seats
Reverse lights
Sideskirts
Centre console lid
Front indicators
Headunit
Boot/fuel cap cable
Gearknob
Headlights
Strutbar
Din pocket
Passenger mirror
Gauges
Drivers side mirror
Gearbox
Clutch
Flywheel
Tailshaft
Spoiler
Front guards
Aircon lines
Rear boot trims
Steering rack
Items Sold so far:
Rear wiper motor
Front seats
Reverse lights
Sideskirts
Centre console lid
Front indicators
Headunit
Boot/fuel cap cable
Gearknob
Headlights
Strutbar
Din pocket
Passenger mirror
Gauges
Drivers side mirror
Gearbox
Clutch
Flywheel
Tailshaft
Spoiler
Front guards
Aircon lines
Rear boot trims
Steering rack
Diff
Items Sold so far:
Rear wiper motor
Front seats
Reverse lights
Sideskirts
Centre console lid
Front indicators
Headunit
Boot/fuel cap cable
Gearknob
Headlights
Strutbar
Din pocket
Passenger mirror
Gauges
Drivers side mirror
Gearbox
Clutch
Flywheel
Tailshaft
Spoiler
Front guards
Aircon lines
Rear boot trims
Steering rack
Diff
Wheels and tyres
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
