just in the last couple of stages of putting my engine back together. and wondering why i need a catch can? it is a rb26 running 2560 -5s, cp pistons, eagle rods, acl bearings 700 injectors and looking at runnning about between 22 and 24 psi. so any info or advice or a good answer to why i need a catch can and not run it all the standard way
You dont HAVE to. All it does is seperate the oily mist from the air.
Stock setup it gets drawn out of the head into the intake pipes under boost, and inder Vac it is drawn out via the PCV too. It could possibly lower your octane rating slightly if you have alot of it. And it can also coat your turbine wheels and intercooler + pipes in an oily film over time.
Its up to you.
If you have the N1 oil pump, chances are your head won't drain quick enough, even with the additional rear drain.
RB's are notorious for this, also one reason why so many Rb26's lose the main bearing.
I have RB25/30 with N1 pump, all oil feeds left unblocked, and no rear drain.
On my last track day , on hard left turns, my right side rocker cover filled up with oil, then the PCV spewed it all into my plenum and back out through my BOV all over the track.
Then again on acceleration out of the corner I had so much blue smoke, couldn't see the car behind me.
Oil dripped out the BOV for the next 6 weeks, and it probably sucked back into my intercooler too.
Block off your PCV at the least, and save your engine.
So when you do set up a can, as rice says, make it catch oily vapour too, keep that shit out of your intercooler.
Do the stainless steel wool gig, every bit helps.
    • The larger TB I had on the SS was a pain to get to idle right, but, that was cable In the end they just raised the idle up a couple of hundred RPM so it was happy idling away either in gear or in park (slush box life) I'm curious on how my NC will idle with the new intake, larger TB, and cams that are currently going in/on, but I have faith that MX5 Mania will sort this "electronical" "black magic" out the best they can in the tune with a electronic TB Sometimes I wish I knew more about the intricacies of tuning, but most of the time I don't because I know it would hurt my brain 馃ぃ
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
    • The GTR strut brace clears the new manifold.. by about 0.5mm. So this means I need to buy an OEM GTT Strut brace (again), which will clear the new manifold, but not the bonnet vents. I guess I can sell the GTR Strut brace with the bonnet with the vents as a package deal as someone will need this one day. So my choices are vented bonnet but no strut brace, or GTR Bonnet with OEM brace (which I have to buy) but is bright red instead of the same colour as the rest of the car, which means the entire front end of the car will just be red until it goes back to paint jail. In other news the engine starts and doesn't leak. Why both O2 narrowband sensors think the tune is rich AF I do not know. The idle is also pretty shitty and my expensive IAT sensor from the USA is dead. The car sounds awful. But I assume or at least hope this is due to the many exhaust leaks, and the concrete garage it is in, sitting there with 0 intake bolted to it, and no bonnet or panels or anything to stop the induction/intake sound which is about 200db.
    • C'mon! At least come kicking and screaming into the 2000s. BA XR8 bulge.
