just in the last couple of stages of putting my engine back together. and wondering why i need a catch can? it is a rb26 running 2560 -5s, cp pistons, eagle rods, acl bearings 700 injectors and looking at runnning about between 22 and 24 psi. so any info or advice or a good answer to why i need a catch can and not run it all the standard way
You dont HAVE to. All it does is seperate the oily mist from the air.
Stock setup it gets drawn out of the head into the intake pipes under boost, and inder Vac it is drawn out via the PCV too. It could possibly lower your octane rating slightly if you have alot of it. And it can also coat your turbine wheels and intercooler + pipes in an oily film over time.
Its up to you.
If you have the N1 oil pump, chances are your head won't drain quick enough, even with the additional rear drain.
RB's are notorious for this, also one reason why so many Rb26's lose the main bearing.
I have RB25/30 with N1 pump, all oil feeds left unblocked, and no rear drain.
On my last track day , on hard left turns, my right side rocker cover filled up with oil, then the PCV spewed it all into my plenum and back out through my BOV all over the track.
Then again on acceleration out of the corner I had so much blue smoke, couldn't see the car behind me.
Oil dripped out the BOV for the next 6 weeks, and it probably sucked back into my intercooler too.
Block off your PCV at the least, and save your engine.
So when you do set up a can, as rice says, make it catch oily vapour too, keep that shit out of your intercooler.
Do the stainless steel wool gig, every bit helps.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
