so i drove my car from work to a mates place, drove fine, turned it off. turned it back on about half an hour later, idled fine, drove out the driveway, gave it a bit of a squirt, came to an intersection and went to pull out and it started to choke and had absolutely no power and just died. i turned it back on and it was idling between 200-1500rpm going up and down. roll started it and drove it down the road, seemed to drive alright down the hill, then when i came to an uphill it died as i started to drive up the hill. its always had a problem doing hill starts due to what i think is a leaking injector. also im not running a tps cause its got an rb25 engine harness for some reason. but usually if im already rolling when i come to a hill its fine.
im going to swap over to the rb20 harness, and put some new injectors in it. just wondering if there's anything else i should check. cause it drove fine from work, only after i went to drive it again it shat itself.
:( hate cars!
OMG benm has an impostor!
I would start by looking for a boost leak, especially if it is not idling properly. there are lots of vacuum hoses and a single split could cause an issue.
:( hate cars!
Wut?? what good would an RB20 harness do? Why doesn't it have a CAS?
+1 for intercooler piping leak.
Afm dude had same problem idal hunting like crazy no power then al of a sudden all is fine untill it does it again . Mine also would hit like a miss that sounded a bit like a rev limited at about 4,xxx rpm. My idal was between 800-1500 and would go up then like stall then Kik up then drop so annoying but Afm was my problem. Try throttle body cleaner or some sort of contact cleaner . Or replace also check Afm plug
It happened just after
...gave it a bit of a squirt...
didn't it?
You have a significant air leak after the AFM and before the throttle body. Probably popped an intercooler piping connection.
well the rb20 harness may be useful as i have an rb20? and i need the tps (throttle position sensor) as it controls alot of things.
could a leak pop up that quick?
In an R33?
i pulled the pod off, fully covered the afm and it didnt even try to die. just kept idling away fine. managed to narrow the leak down to somewhere between the afm and turbo outlet. pulled all the piping off and no splits or anything. so i have no idea where it could be coming from? also for a while it would idle like shit, going between 200-1500. then when i unplugged the afm it idled smooth and consistant?
Blowing smoke at all?
Grab a multimeter and check your AFM. The Nissan FSM has the instructions - you just check the signal pin on the afm to earth (engine/body) to see what voltage its reading. 0.3v ign on but not running, and something like 1 or 1.1v while running. Easy peasy and will rule that out.
Next find your consult plug in the drivers kick panel / fusebox area, and do the ecu self diagnostics. again, instructions in FSM. This will give you some flashes on the dash to tell you what the ECU reckons is wrong. Match the flashes up to the chart in the FSM and go from there.
If there is no flashes, then it's probably an air leak.
You have a compressor and an airgun?
Take your air filter off and use duct tape or something to seal up the end, unplug a vac hose in the intake system (before throttle body), and shove the air gun in there and let er rip. You could also rig up a tyre valve to do it with a tyre inflator but that's more effort.
Anyway you'll want a friend to help you find the air leak. try wetting your palm and holding it around the joins of the IC pipework. also with the engine off and intake pressurised, you will likely just plain hear it hissing out.
I think the last thing could be a borked IACV thing - maybe its jammed open/closed or something, don't know too much about how that works whistling.gif
unplug the AFM when the car is running, if the engine is still running then it could be AFM....car is meant to die straight away when unplugged.
Also because you gave the car a squirt you could of blow a piping off or a slightly came off....normally when IC piping comes off you will know about it lol gives a big bang
it could possibly be my air flow meter? although i've got two different ones and i've tried them both and nothing changes, and i wouldnt have thought they'd both be rooted. just after it happened my car was idling really weird, so i unplugged my afm and it started idling fine, then plugged it back in and it died. its at the mechanics now. they're going to go over everything, flush out the fuel rail, check injectors and replace o-rings.
i took off every single bit of piping and no leaks or cracks in the piping or joiners. all manifold bolts are fine and not warped. its currently not running a tps but the plug is in place, just needs wiring up.
    • Yeah, the latter. No diff should have a centre replaced without checking clearances because its unlikely to be the same as whatever came out. Not that that stops most people just checking a new centre in
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
