you can still have good offset rims and good handling. you just don't need to dump it on the ground and ruin roll centres.
plus, macpherson struts greatly benefit from negative camber since under corner the camber angles changes vastly more then a multi-link or a double wishbone setup.
not saying that hellaflush is good just saying you can have a bit of both worlds.
Edited by Peter89
Lol not my fault that everyone on Sau drives boring cars that all look the same :)
lol your kinda the same but kris
your always like 281KW 281KW 281KW!!
person- ugh your orange blinds me
kris- yeah well i have 281 rwkw
person- oh nice
kris- YEAH THATS RIGHT BITCH YOUR MUM SUCKED ON MY 281rwkws
person- errrr i was just voicing my oppi kris- 281RWKW BITCH!
you know i love you krissy :kiss:
  • 3 weeks later...
    • Depends how low and tyre size. Should fit with natural camber, skinny tyres and rolled guards.
    • Hi guys, planning to get 18x9 +25 in fronts and 18x10 +25 in rears been reading the whole thread and cant really find anything   Anyone know if these will fit a r34 gtt with no scrubbing or guard work needed?
    • They usually get made by hand as part of any such swap.
    • Was planning on getting an R35 MAF and the adapter, should this be okay? Also any idea where I could get my hands on an intake pipe?
    • I mean yes, if you're starting from scratch on an unknown engine yes you don't need to be doing all kinds of math in the background but if you're doing relatively minor changes like AFM + injectors + boost up with some aftermarket turbos it takes quite a bit of math if you want to do something like maintain OEM fuel + timing tables but compressed and then a bit more load scale up top. I think I've spent too much time working on big engineering nightmares though so I'm a big fan of trying to constrain the scope of whatever work I'm doing as much as possible and trying to get it right before moving on. For example, a local owner just did the usual E85 + single turbo conversion to his R32 GTR and nearly burned his car to the ground doing some spirited driving up the local mountains. Turbine is unshielded and too close to the hood insulation. It's tough to balance "just get the project done" and "seemingly small details can cause massive setbacks I'm not willing to deal with".
