So, you might be able to snare a spare 'access all areas' pass for a beloved SAU Admin? :ninja::D :D :D
I take it from your sig that the RB27 makes significantly more power now, than the 298rwkw figure from 2007 - given you have run an 11.24 pass. VERY impressive time indeed!!!!! Is that 2wd or 4wd?
HAHA, i wish i could get spare passes, i couldnt even get one for my wife when she went to the Gold Coast round last year with me.
Thanks for the comments about my car, but it still only makes just under the 300rwkw to run the 11, its all about the tyres.
Cheers
Luke
Wow that is an amazing time for that power level - with a 1.61 60' you must really hook it up! I know what you mean it is all about tyres .... back in 2003 I did a 12.74 110mph in my S15 and it only made 200rwkw - but it would do consistent 1.6-1.8 sec 60' times with decent street tyres - and it was my work car that I drove there and drove home at full weight.
That is one of the vids from the day,
Im the first car on there, with R33 with black bonnet and NUTR33 on the plates.
Hey Whiplash, what do you do with VodkaO, on one of the teams or an organiser?
i will be in a fadded orange Chanel7 shirt that looks 2 sizes to small for me working on the cameras, come and say hi if you like.
Cheers
Luke
Looking forward to being trackside agai this year, but probably only Thursday and Friday. (In the usual spot if you want to drop past)
So you'll miss the fashion shows behind your seats on Saturday and Sunday :closedeyes: 1st no Schutzenfest and now bailing on bikini parade.... you changed man :action-smiley-069:
Wow long time no hear Guy :) - if you are after a ticket for either Saturday or Sunday on Pit Entry Gold, I am selling some tickets at $85 per day. Or I still have a 4 day pass for $185.
Good to catch up with you today Nick.
They have destroyed our usual shade tent, but the fashion parade catwalk is still there, and the XXXX girls trailer was backed up for a show today.
Back again tomorrow.
Hopefully I get to spend most of the day in the corporate section (again) enjoying the free food and drinks.
yeah mate,
sorry couldn't hang around longer, with all practice and qualifying today it was a bit mad.
just got home after 14 hours at the track :huh:
oh and if your down near the GT paddock come and try our simulators, set up with the GT cars and the adelaide track :pirate:
1 hour race was great at night,
From the press release:
GTR I found sitting in front of the GT paddock
Our poor Lambo suffered a lower control arm failure during the race.
Andrew and I apparently stared on the Super Screen today :whistling:
Was chillin with my "old mate" Murray Walker on the podium today, watching the GT race, got a few photo's with him, whilst holding a bottle of Vodka O :thumbsup:
Vodka O porsche needs a heart transplant, don't think its normal for the oil to be 30% metal shavings :-(
I tried to find you this morning to no avail :( did pass murray in his golf cart though on the walk down to the GT pit area
Apparently andrew and pete tried to find me, but i musta been off escorting the guys in "yowie" suits around
amazing how far a green uniform gets you in the pit area :laugh:
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
