  • 4 months later...
well its been a while but here is what i have done so far
Some 'glass to hold things in the right place...
more 'glass 'n' mdf
almost done one box... the other just started :)
Scriblez i will be doing 99% on my own, thats why its taking so long to get it done, but i think it will be well worth it.
AAA34T, i havent even looked at that yet , that will be done in in the next months.
Ezekiel86, what system do you have in the 260?
Dude your sense of achievement is going to go through to roof once it's done. Good Job mate :thumbsup:, can't wait to see further progress.
I'm gonna be doing something similar to this but only 2 subs on 1 side so I can still use majority of the boot space to carry stuff around.
Ok so my sterio was big then I cut it down fron 4 amps down to 2 and from 3 subs to 1to start draging it and to beable to put my toolbox in the back. The alternator was a pain I had to get the biggest amperage alternator that could find in the standard spot I used bosch 120a alternator vl commo alternator housing and the standard pully the bosch alt would not bolt up and we stripped the bosch 120a internals and put them in the vl alt housing because they would not fit in the standard housing and the vl is a little bigger once all back together works almost great but needs a smaller pully alt does not charge below 1000rpm my car never stops so no major problem for me
  • 1 month later...
  • 3 weeks later...
it has been a while since i have posted here , ran out of fibreglass, and had no time to get more until a few weeks ago. here is an update video
just testing air leaks and the like. on the handheld Db meter i have, 130Db :)
in theory, you should wire each subs coils in series, then parallel the subs together
It is far less desirable to make subwoofer to subwoofer connections in series. Because of slight and unavoidable differences between speakers and because of the high likelihood of uneven loading between different speakers in a car, there will be slight differences in the mechanical behavior of the two speakers in series. These differences in movement result in induced voltage (called back EMF) being created by the speakers across the series connection. This effect causes a problem when two speakers which behave differently are connected in series because the speakers can modulate each other (cause each other to move), resulting in distortion. The problem becomes more serious as more speakers are connected in series.
A good experiment to show the effect of back EMF is the following: connect four speakers in series and short the positive and negative input leads of the series circuit. Push down on one cone with your hand; you will notice that the three other speakers will move in the opposite direction of the one you are pushing. Now, reconnect the speakers in parallel, short the inputs and push down on one cone. The speakers will not modulate each other because each one is shorted directly.
Back EMF modulation is not a concern when the voice coils of a dual voice coil speaker are wired in series to each other because the coils are physically coupled on one moving mass. Therefore, they cannot possibly modulate each other because they cannot move independently.
http://mobile.jlaudio.com/support_pages.php?page_id=163
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
