  • Replies 58
you wont get a voltage checking like that.
Its only gonna register at the point in time when it is actually sensing knock.
basically theres a crystal in there and when it is compressed it will output a voltage, between 0.4-2v depending on the severity of the knock.
I guess you could try tapping the sensor or the engine while hooked up to a multimeter.
Edited by battery
Figured that much...
Only when it actually picks up noise then it would output a voltage
Another glitch in the manual i suppose as the R32 gtr manual doesn't mention using a circuit tester, just an oscilloscope
I guess the sensors are working though because they are registering an increase in knk from off to on load
So what do you guys recommend? tune for a max knk of 15 ish? I would really like to see a similar log of a stock 26 tuned on 98
I have a next set of sensors that i could swap but i really dont think that will make a difference
its not supported in Nistune yet... Matt has been working on it for years :)
every engine has different noise, you dont just have a level that you should try and stay below, i have seen engines register 150 knock and when listening to it I cannot hear a thing!!
What you should be on the lookout is for major spikes, if the engine makes contstant noise but then spikes from 40 to 140 then you might be onto something...
can you sent the car to the states ? there might be some decent tuners there?
my nistune software doesnt show any knock (0) dunno why?
does anyone know which cable on the ecu harness is for the knock sensor?
Well that's good to know, I was abit worried that my knock sensors mAy have been disconnected .
Why would nistune have the knock feature in the software but not have it supported yet? It's a pretty dam important feature
My 32 GTR knock sensors never worked either. Dont know why. Tried new sensors, loom continuity, all good. The factory knock sensors should never be relied on anyway.
To tune it on the road you need a knock box. Theres no other way. Either that or you need a proper dyno tune by someone who knows what theyre doing.
I'm noticing something in my car I wasn't before. I had a PFC with base tune and that thing used to register about 40 - 50 knock sometimes up to 100 knock. I got one now tuned for a stock R33 GTST with 10psi. I see about 4 on average on the knock sensor, very rarely shoots up to 10 - 30.
Now, originally I had the standard dump on the car and it was leaking coz of a crack and you could hear the look coming onto boost. I changed it out for a screamer split dump while my other one got fixed. Now I fit the other one back on and I get a weird tick tick tick sound which only seems to happen between 5000 - 6000rpm. It picked up my attention straight away. Ive never heard the sound before but it only happened when I got the old dump put back on after it was fixed. People say pinging sounds like the word, like a ping on metal. This sound I hear is more like a "chick" kind of sound, like a match getting striked on a match box.
Knock sensor on my PFC still wont show anything above 15.
And to OP, the Power FC will detect knock as its heard from your knock sensor. Your car is designed to detect knock but it does not display anything to you. The PFC just reads what the knock sensor says and displays it for you. You need an independant knock sensor. But that said, if you're still picking up some form of knock, your sensor probably is working. Like others have said, if its a ping so loud you can hear it, there is no reason your knock sensor wont.
sarge if its on a pfc even though the knock is reading 15 if you can hear the chick sound, try going to ign trim and back the timing down 5 degrees to see if the noise stops. dont keep booting it till you figure out if its pinging or not.
Buy a knock box, then you could start your own tuning workshop. :yes:
Dont have time for that.....
I just like my car and want it working up to scratch
That statement is so funny you wouldnt believe...
I realise you guys have a lot of dodgey tuners up there so imagine for a tiny island like mine.
  • 1 month later...
Well time for a little update......
I have secured all sorts of loose shit under the center console/dash and under the car and tuned the timing around 24* which is what the oem ecu would normally run and i'm not hearing any vibration/rattle again and the values on the pfc is 10-12 max and very low on the safc2 as well and i have that set really sensitive
So i believe that the noise wasnt actually detonation but i have taken out a few degrees here and there so the safc would not show any high values like i was seeing before.....so i guess now its dyno time to compare ign advance to torque gain to see where shes happy
Man....talk about paranoid!!! every fu$king thing sounds like detonation!
Any tricks to listen for knk on the dyno??? With your bare ear i mean.....i just dont have any other devices available to pick up knk
There are no tuners here with knk sensing devices and they are really bogus in my book thats why i bought the pfc in the first place to have some sort of detection
95 is the best we have here too and i'm running 11.0 afr from 4k up
imo the standard knock sensors are more likely to be bogus than proper knock ears, I would certainly get some on there to tell if it is your knock sensors playing up or it is just some mechanical noise.
think of an engine as a woman. there are many ways to get her to bed, once you get experienced enough you work out the fastest and best way :)
But dont expect a guy to tell you his secret, he dont want you taking all his women... took me a while to understand why experienced tuners keep their knowledge to themself's like they do.... but i would have it no other way now.
I don't really get this, in a lot of circles everyone shares info and works as a team, (eg forums) I guess when money comes into it it is different though.
SAU is good for info like that, go ask a V8 builder about their Jet specs for a carburettor, you would be lucky if they didnt back hand you, same goes for cams/port work, the good guys wont tell you nothing, I know heaps of guys with Big power race V8s who dont even know what the specs are because the builder wont tell the owner.
It makes perfecet business sence, because the good guys earn good money becuase they are good, if they gave away their secrects then every wannabe pro-engine builder would copy them.
Imports are easy because everyone is lazy and leave the heads stock or near stock and just add boost, and its easy to look for the plate that says "GT3037S" etc and build the same engine.
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
