Item Summary: 2001 NISSAN 200SX s15, 400hp+ rb25det stand out!!!!!!!!!!
Postcode: 4216
Asking Price: $24,000
Condition: Used
Reason for Selling: cash want v35
Delivery Methods: PickUp
Contact Info: Denise 0404052011
Extra Information:
2001 NISSAN 200SX s15, one of a kind beast!!!!!SWAPS
Up for sale is my baby 200sx s15 i have spent a lot of time and money on her and now i want a change and more room for my family. So if you have a nice skyline, bmw, wrx or just a nice import at same value or i will swap with cash my way. This car is one of a kind and you wont be disspointed, if you love attention then this is the car for you.
The features include:
2001 s15 nissan
Cammo black and gold (east coast customs old car but have touched up parts and new front bar) paint is awesome in the sun.
fibreglass bonnet approved and front guards
Built Rb25det and 5speed
fresh built rb25det decked and honed with new nissan rings
acl race series bearings
arp stud kit
1.88 cometic head gasket,
fully ported head
brand new timming belt kit,
full set of rb26 covers polished
coilpack cover painted the same as car
greddy copy plenum with 80mm throttle body polished
brand new denso 550cc injectors top feed
hks purple fuel rail brand new
z32 air flow meter mounted in intercooler piping
bilet fuel reg and gauge
walbro 650 hp intank pump
battery in boot
stainless exhaust manifold custom made
t66 turbo with 4inch purple bell mouth or drift pod
38mm turbosmart gate
full 3 inch alloy cooler pipping with 600x300 cooler
3 inch exhaust system with big cannon
new apexi power fc with ahnd controller computer
50mm tial bov
52mm alloy radiator with twin thermos car runs at 84 deg even on dyno
has had a safe tune done at 420hp on 18 psi, engine has lots more potential to go 450 500 ,engine built to run high boost
r32 k frame and mounts
custom 1 peice 1000hp tail shaft
tuff r33 rb25det gear box with exedy heavy duty clutch
black tinted windows
custom tail lights
gizzom ibc boost controller
stereo sound system
brand new lenso D1R rims and tyres
tein coilovers
black leather front seats
plates not included
6 months rego
call if u want
$24000 ono cash only for quick sale or swaps value at around $28000
interstate buyers welcome
follow link to photos!!!!!!!!!! http://www.boostcruising.com/forums/index.php?showtopic=706698
https://www.sau.com.au/forums/topic/356936-nissan-s15-200sx-beast/
  • 1 month later...
  • 1 month later...
    • Hi again all, I’ve tried doing some searching on the topic but couldn’t find the answer I’m looking for.   I deleted my clutch booster because it had an air leak and was squealing like a hog, and now my clutch has very poor pedal feel and the friction zone is way too small, so I believe I need a bigger diameter clutch master cylinder to compensate for not using the booster. I found a Wilwood option that’s 3/4” for a good price and will fit my 3AN clutch line, but all the firewall adapters I see online such as RB factory or Chase Bays are listed as RWD only (GTST/GTS). Link below. https://rbfactory.shop/products/nissan-to-wilwood-girling-clutch-master-cylinder-adapter My question is if these adapters will also fit a GTR, and if anyone has experience using a 3/4” CMC without the booster, my clutch is a Nismo coppermix twin plate.   Thanks, always appreciate the advice!
    • Catching up on a post, I've replaced the external shark fin with a small 4g antenna (no further drilling, just a 1mm embiggening of the existing hole, and run that to where the dual battery models have the battery in the left rear guard.  No idea what the factory antenna did, but removing it had no impact on anything I use, according to the US manual the GPS antenna is in the dash and it still works fine Also ended up stealing battery power from one of the amps and ACC power from a unit nearby to add an ACC relay to power it. The mounted the booster, wifi, power socket and antenna splitter in the rear left guard out of the way, all out of site with the boot trims in
    • What drama? The only drama you're going to have is the near constant work to maintain all those sphericals. I only have sphericals in my front caster rods and front upper CAs (because both of these are near compulsory in an R32). I have had the front arms out of my car 34 times already this month, and if the new replacements arrive today, I will have them out and apart again tomorrow. Chasing clicking and clunking that comes from sphericals being a.....poor choice for a road car. Moisture and dirt are not their friends. I have been contemplating a change to my rear subframe that would require me to use sphericals in my lower CAs. And.....I don't want to have them that close to the road.
    • Did you need anything else you've already done? If you had it before... and liked the changes after, then supposedly it'd be more of the same. The idea about most suspension arms is to tune geometry that the OEM arms max out at/can't handle because they weren't designed to have the car setup in such a way that 'looks good'.
    • I have replaced everything on my r34 including suspension to Miester R, all rear subframe bushes to poly, all arms to metal adjustable and same in front.   only thing I haven't touched is the front lower control arm. Should I? what improvement can i expect ? I mean the one on the link below?   Car drives perfectly, it is just me thinking everything is either puly bush or hard bearing type so should also do lower control arm front but do I really need it ? https://www.japspeed.co.uk/product/suspension/adjustable-arms/nissan-200sx-s13-s14-s15-skyline-r32-r33-r34-adjustable-suspension-front-lower-control-arms/?gad_source=1&gclid=Cj0KCQiAo5u6BhDJARIsAAVoDWs5V_PauQPf0kx3zFCaA4tOC9Q7JSIsfJWma_jAPN2f1sJA686djOwaAidgEALw_wcB
