I am looking at getting my R33 GTR gearbox with OS Giken gearset rebuilt.
Anyone know what I would expect to pay for a rebuild with all new series 3 GTR synchros?
Also, does anyone recommend a good gearbox rebuilder in Melbourne??
I'm looking at rebuilding mine when the new clutch is going in. The quote I got from my mech is around 1.8k-1.9k with labour and oil etc.
I had an occasional crunch into 5th even when changing at a casual rate also the odd crunch on fast changes into other gears. I put in Redline Shockproof Light and it pretty much all went away. It crunched once into 5th soon after putting it in but not again for the last 3-4,000kM. Occasionally I feel a slight grab into one of the other gears, but not a crunch. For my g/box and hip pocket Redline Shockproof Light was the answer.
Crunched hile trying to get into fifth on the weekend. It just didn't want to go in. It was like I wasn't even using the clutch. This was at 1.5hours into a 4 hour drive. Didn't do it again. For now I'll just live with it.
Redline lightweight shockproof gearbox oil.
Get some off Harold from PerformanceHub on eBay.
Mate had exact same problem, the above fixed his.
Not cheap, approx 120ish?? for the oil, but definitely worth it, don't skimp on cheap shit.
That's me :D
Discovered my crunch at Powercruise, Redline sorted it out. Hasn't done it since. Well worth the money I paid for it, +1 for Harold (@ PerformanceLub James :P ).
  • 1 year later...
You'll find just about all boxes will if you try too fast of a gear change. Same with my RB25 box in my 31 and the GTR.
4th to 5th demands you be a little slower I've found for whatever reason. It is the smallest gear too remember.
Doesn't do it if you just give it that half second longer.
why is it one person says this when everybody else says you need new synchros or oil. :unsure:
I will try this before I try new synchros or oil and report back anyway..
Never really noticed an issue with my box apart from the occasional low gear crunch when cold...
untill Phillip Island, only really on the main straight, flat out trying to change into 5th was horribe CRUUNNNNCH!!!!
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
